Camshaft question
Old 12-31-2008, 03:37 AM
First off, Welcome to the forum!
Now onto the questions. As far as using the cam in another motor, you can, BUT.... It depends on how long that cam has been in the motor that you got, How the motor was run (beat on or babied), Are there ANY markings on the loobs, what do the lifters look like on the bottom. There is a lot to look at when doing this. If anything I would leave that cam in the 360 and get a brand new one for the 318. You don't want to chance it.
As far as the numbers go, I can't really help out out. Sorry. I would run them through some performance part websites though and see if anything comes up.
Old 12-31-2008, 08:44 AM
if you can, look at the cam. check the lobes of it to see their condition.
Old 12-31-2008, 03:10 PM
challenger's Avatar
welcome to the forums MJ and as far as the lifters i would throw them AWAY and not look back and look at the wear on the lobes to see if it is an even wear but i would just stick it back in the 360 as the cam bearings are allready worn to that cam but what was your oil pressure before you took it apart ?? Buy a new cam and save yourself any headaches further down the road and always replace the cam bearings for a new cam / never use old bearings on a new cam as like i said they are wore to the cam you pull out
Old 12-31-2008, 03:30 PM
i woudl go for a new cam and lifters
make sure you are using an oil with zinc in it
Old 12-31-2008, 03:50 PM
challenger's Avatar
the pic of the cam didn't come up last time i opened this thread up but it did this time and what i see is rust so GET RIDE of it and go with a mild new cam and lifters as the rust makes pits and its very hard to get it out with out destroying the lobes
Old 12-31-2008, 05:06 PM
Crazy4Carz.Com's Avatar
Take the cam to a good machine shop and they can "read it" for you. They will measure the lobe separation/lift/duration and you can buy a duplicate if that is what you want.
Old 01-01-2009, 06:53 AM
X3 on getting rid of that cam, lifters and bearings.
Old 11-08-2021, 02:46 PM
65Val's Avatar
I’m in the same boat. Just opened up a 360 from a friend and has this same cam in it. Anyone figure out what it is?
Old 11-09-2021, 07:36 AM
haha, seeming like it's the stocker.
Old 11-09-2021, 08:45 AM
65Val's Avatar
Stockers usually dont have numbers or paint marks on them…also has “C141 numbers as well…
Old 11-09-2021, 10:50 AM
Guessing it is just a OEM style camshaft.
THEhomelessONE
12-26-2016 10:08 AM
1968GTX
31
02-19-2014 10:00 AM
hunter1464
05-23-2013 09:09 PM
silvermopar
09-20-2009 07:26 PM
craveman
04-12-2009 03:56 PM
Quick Reply: Camshaft question
