Go Back   Mopar Forums > GENERAL > General Technical Questions
Thread Tools Display Modes
Old 12-23-2009, 08:25 AM   #1 (permalink)
1OldFordMan
Member
1OldFordMan's Avatar
Engine / tranny info.
Howdy Mopar folks. I'm leaning toward a Mopar when I sell my car. What I want, I know I can't afford ( how many million? ). What I'd like, I doubt I can afford either. So what I'm thinking is buy something with no motor / tranny & put one in. Here's kinda what I'm thinking. I'd like to find a Duster / Demon, Aspen / Volare, Dart / Valiant type body style & put a 360 w/ overdrive in it. I had a '94 Ram 1500 I bought new off the lot like that & was pleased with it. I want to go carbed & don't know what all I'd be looking at. I know they made this body style with the small blocks, so I'm sure the engine would fit fine. What I don't know about is what about the tranny. Is it like the FORD E4OD where I would have to have a computer to tell it when to shift ( lock up converter? ), etc. To be clear, I don't have anything yet, I'm just looking for ideas & advice. I figure if it's a Mopar question, this is the place to ask it. Not that good at all this, looking for something simple / cheap. One reason I want to go carb instead of fuel injected. Please be gentle, I'm a FORD fan experimenting with the dark side & possibly on my way to being converted ( or at least part way ).
__________________
shstartrolet should be a 4 letter word!
1OldFordMan is offline   Reply With Quote
Old 12-23-2009, 09:53 AM   #2 (permalink)
John Van
440 lover
John Van's Avatar
nice to hear you wanting a mopar! What are your plans? Is this going to be a daily driver,cruiser? I would first check your state's vehicle equipment/emission laws to see what is allowed.I think a pre 1985 car would be the way to go with a 904 tranny (no computer)!
John Van is offline   Reply With Quote
Old 12-23-2009, 10:35 AM   #3 (permalink)
1OldFordMan
Member
Quote:
Basically a daily driver. just want something to happen when I push on the skinny pedal. Isn't the 904 a plain ( no OD ) tflite? Was hoping to put an overdrive tranny behind it. Can't push a clutch ( long story ), so I've gotta have the auto. That's where I'm wondering, are they computer controlled or do they make a non-computer overdrive tranny? I've got an F-150 & have been reading a lot on their site. I know from that, that it's possible to get a separate OD unit or for the FORD E4OD, a separate controller for the tranny. Either way, BIG $$$$. My funds are limited ( isn't everybody's? ), that's kinda why I'm thinking of buying the body only & then buying a motor / tranny to drop in. That's why I said 360, I'm sure that body style came from the factory with a small block in, not all of them were slant 6s. This way, there's no big hassle with custom motor mounts, custom this, custom that. Basically just a plug & play setup. Doubt if I'd ever have the funds to buy something with a big block. What I want is a 4Bbl. & duals. Not trying to build a race car, just something to have a little fun with & a little more than the factory built it with. I'm thinking something from mid '60s to mid '70s. A 360 is basically the same as the other small blocks, right? I meant as far as external parts. Example if a 273 was there, you could replace it with a 360 & maybe just change the exhaust, possibly the radiator depending on what angle neck you have for the thermostat. This is what I'm thinking, but not real familiar with Mopar.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Viper engine/tranny for sale or trade Liu Kang Mopar Classifieds 17 08-18-2009 06:38 PM
info requested re: 361ci dodge engine bighammer B-Body 7 05-02-2009 07:23 AM
Tranny swap NEED info help wcturn Do-It-yourself Section 2 08-11-2008 06:59 AM
what tranny do I have? tdmorgan77 General Technical Questions 3 04-09-2008 09:10 AM
1971 charger info big block info 71charger B-Body 1 04-02-2008 05:22 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
