oil pan leak
Old 08-03-2016, 03:45 PM
stevestefko's Avatar
oil pan leak
I have an '86 d-150 pickup. it has a 360 motor. the oil pan leaks at the front and rear. do I have to lift the motor to drop the pan? any other advice on changing the gasket and lower seals is appreciated. thanx
Old 08-03-2016, 05:08 PM
I believe you do need to raise the motor, disconnect the drag link, remove the trans inspection cover. May also need to rotate the motor for the crank counter weights to clear the pan
stevestefko (08-04-2016)
Skynyrd
09-10-2014 05:24 PM
MarkyMark12345
04-10-2009 06:43 PM
dzltd02
10-28-2008 08:25 AM
robertoil
01-25-2008 05:34 PM
Quick Reply: oil pan leak
