Tapping Noise
Old 08-16-2010, 12:40 AM
MichaelSB's Avatar
Tapping Noise
Hello from England
I am hoping you guy's may have an idea what is wrong with my Jensen Interceptors engine, it is has a big block 440 engine.
The problem is when I start the engine from cold I get a loud tapping noise which gets quieter when the engine is warmed up but never really goes away.
Most people have suggested it is exhaust manifold leak or hydraulic lifters, I have replaced the manifold gaskets and all 16 hydraulic lifters but no change.
I have now ordered from Mad Dog in the USA a set of adjustable rockers which I hope will be here soon but as you guy's know these engines better than anyone else I thought it was worth asking you.
The engine was rebuilt a few years ago and has only done 12000 miles since then, the oil pressure is good and there are no other symptoms.
Any help please
Michael
Old 08-16-2010, 08:31 AM
A.K.A Bob Dodge
1966sportfury's Avatar
did you check for cracks in the manifolds? or at the collector of the manifold? i have a hard time thinking the rocker shaft being that worn, i think i would try lash caps b4 buying new rockers, thats just me tho,
Old 08-16-2010, 11:40 AM
MichaelSB's Avatar
Hi Bob
Thank you for the advise but what are lash caps I'm from England so we I guess have another name for it.
Old 08-16-2010, 12:08 PM
A.K.A Bob Dodge
lash caps go over the valve stem to make up any unwanted play at the rocker. they go ontop of the valvestem under where the rocker contacts
98 SNAKE EATER
03-28-2013 04:49 AM
Beepbeep71
06-15-2012 06:13 PM
sixpack_sid
11-03-2011 08:41 AM
SPICOLIE203
07-05-2011 01:51 AM
DodgeW200
10-04-2010 02:21 PM
Quick Reply: Tapping Noise
