trans cooler
Old 11-19-2010, 03:30 PM
67Polara's Avatar
trans cooler
when i pulled my old engine out i think i striped the fittings where they connect to the radiator, how would i fix this ?
or would it just be a better idea to get a extrernal trans cooler ?
and if i do, would i need to plug the holes where the fitting were ?
Old 11-19-2010, 05:20 PM
fivepoint's Avatar
I would see if the threads can be repaired either by yourself or a good radiator shop. An external cooler will work if its a good one and placed where it can get enough airflow. If you use an external cooler, you would not need to plug the old radiator fittings.
Old 11-20-2010, 10:52 PM
67Polara's Avatar
cool. thanks man
Old 11-21-2010, 01:10 AM
toad490's Avatar
Ditto on the external cooler, an upgrade that should be made anyways. Don't cheap out and use rubber extenders and hose clamps on it. Put new steel lines or steel extentions on your existing lines. IMO.
LaurenMagnum360
02-08-2014 07:08 PM
willysman69
10-16-2012 08:51 AM
Dodge Girl
09-13-2012 09:16 PM
Mopar_71
08-29-2010 04:33 AM
68lover
04-29-2010 07:24 PM
Quick Reply: trans cooler
