318 leaking antifreeze into oil pan
Old 03-06-2017, 02:02 PM
Blacksheep's Avatar
my 318 is leaking antifreeze into the oil pan I have the pan off and it seems to be leaking from the rear of the crankshaft right above the oil pump any suggestions would greatly be appreciated thanks
Old 03-06-2017, 08:09 PM
Well... If the intake is not cracked.... And the Head is not cracked on the underside of them.... Sounds to me that would only leave 1 option for the leak. And that would be a cracked block... Ouch..
Just my 2 cents...
Welcome to the sight.... Might pressure test the cooling system and see if you can see where the leak or crack is????
Keep us posted.
Old 03-07-2017, 12:42 AM
I'm with Bob Assuming the cooling system is still hooked up ? pressurize it with the pan off and see where the leak is How much antifreeze ? Maybe it is leaking from the freeze plugs at the back of the motor and leaking thru the pan gasket ????
mar-tay
11-13-2012 06:01 PM
MarkyMark12345
04-10-2009 06:43 PM
angel383
03-04-2009 06:12 PM
dzltd02
10-28-2008 08:25 AM
440doba
05-02-2008 10:18 AM
Quick Reply: 318 leaking antifreeze into oil pan
