318 Poly to Magnum Swap
Hi. New here and need help. I recently purchased a 66 Fury 3 with the 318 poly. When the previous owner bought it he drove it home (5 yrs ago) and pulled the heads off to "see how the pistons looked",threw the heads in the trunk and let it sit. Needless to say I'm not going to just "bolt the heads on" as he suggested. So I either need to rebuild the poly or change it. What I would like to do is get a magnum engine and put it in. Am I correct that it should bolt right in? Is there a kit somewhere to be able to install and retain the fuel injection of the magnum? Anything else I need to know?
There's a guy on Forabodiesonly that will make a harness to use 92-95 mag injection & computer
I've got a couple carbed versions. One with serpentine one v belt
If you have A/C the v belt setup is all you & the cheapest route
myfury3 (05-12-2014)
Thanks for that! I will try and track him down. Found a low mileage 97 engine, maybe he can help me with that.
Kadassa
07-02-2014 06:26 AM
