Help me to buy a carburetor
Old 08-01-2013, 07:35 PM
josehf34's Avatar
Hi Everyone.
I want to upgrade my old Holley 2245 2bbl for a 4bbl mainly in order get a bit more mpg from my mopar and get a better performance.
I want to buy this intake http://www.ebay.com/itm/SB-DODGE-MOP...5f322a&vxp=mtr but I'm not sure about what carburetor should I buy.
In other forum thread an user recommended to me this carb http://www.ebay.com/itm/Carburetor-C...d12880&vxp=mtr but I think a 650 CFM carb is a little big for my 360 V8.
Would be better to buy a vacuum secondaries or a mechanical secondaries carb?
Old 08-01-2013, 08:23 PM
Those 2 barrels work very well.... I dont think your going to see an improvement in MPG by going to a 4 barr. Carb....they just run lean..
Just fyi...
Now if you just want to a 4 barr. carb with a manifold.... Performer RPM with a 650 Vac sec. Holley is my choice with electric choke....
Old 08-02-2013, 07:42 AM
slade's Avatar
always go mechanical secondarys. vacum is **** to fail
Old 08-02-2013, 07:45 AM
O'key-Dow'key.....
Old 08-02-2013, 08:55 AM
slade's Avatar
haha
Old 08-02-2013, 10:35 AM
That carter will work fine, it is mechanical secondaries. I had one on a 360 I also had a 800 cfm Thermoquad on my 360 too !!!
Old 08-02-2013, 04:19 PM
Chryco Psycho's Avatar
so the 650 will be too large but the factory 800 TQ is OK ???
My choice would be a Proform 750 vacuum or mechanical
Old 08-02-2013, 05:06 PM
Buy what you want! spend $100 or $500 your choice. The TQ secondary is adjustable, primarys were small. which is why it will work on a 318 or a 360 or even a 440 I had both on my 360 I even had a Holley 750 on it at one time...
Old 08-02-2013, 06:46 PM
T.Q. Also works great...You just have to keep you foot out of the secondary's.....
Old 08-02-2013, 09:13 PM
That's no fun ! My Volare RR street car would do low 14.20's 99-100mph with the TQ fast enough to make it fun. Doesn't sound that fast but the first time I ran it 69 mph :-(. Still have the carb in the garage & a bunch of parts. I use to cannibalize them at the local pick a part
Old 08-03-2013, 08:08 AM
I'm Running a T.Q. on my Pick up (Warlock) Now from the wrecking yard (Pick-A-Part)... Found it in the dirt, took it home hit it with some caned carb cleaner, threw it on and away we went... One of the best deals I ever got.... $60.00 Bucks....Go figure!
Me too.... Pick-a-part is a great place.... But the Pick'ins are getting mighty slim these days for hot rodding parts....lol
Cheers...
Old 08-23-2013, 11:55 AM
josehf34's Avatar
What about a Rochester Quadrajet on a Mopar 360?
I already had one Rochester Quadrajet from a Chevy V6 on my basement but I don't know how much CFM it has, it needs to be cleaned and restored but I ever listen that they are great carbs
Old 08-23-2013, 04:16 PM
Q.J. Work just fine also... Linkage an install is a little challenging if you dont get the T.Q. Replacement Q.J. But you can make them fit and run good.
Been there done that..
Old 08-23-2013, 04:44 PM
I don't care for the dual bolt pattern manifold
Old 08-23-2013, 04:52 PM
josehf34's Avatar
But please remember: I already Bought this Intake http://www.ebay.com/itm/SB-DODGE-MOP...5f322a&vxp=mtr
Does the Quadrajet Will this fit with no problems or should I continue with the initial idea to install a 4BBL Carter on it?
How much CFM a Quadrajet has?
Old 08-23-2013, 04:55 PM
What Lynn????? Rat Rod come to mind????? lol
Old 08-23-2013, 04:59 PM
Josehf34.... Go with a carb that fits that manifold.... It's easier for you to put on....
The Q.J. might be hard to install....
Kind of hard to find one now... Discontinued....http://www.carburetion.com/Rochester.asp
Old 08-23-2013, 05:54 PM
Q-jet is a good carb and can have the secondary air valve adjusted like the TQ to work on small engines. You'll need a spreadbore adapter plate for that manifold and some fabrication, but if I have just about any carb on hand I use it.
Have you looked at the newer Street Demon? I just bought one for the truck but don't have it on yet for any feedback.
Old 08-23-2013, 09:17 PM
josehf34's Avatar
Yes, I know some people with that Demon carburetor installed on Dodge darts and Dodge demons but all of them conclude that once installed the carburetor the MPG significantly decreased.
I've always read in forums that Quadrajet is a good option for performance and very decent MPG but I begin to believe it isn't a viable option so I think I must buy the carter AFB.
The Q-jet will be a good decorative element in my desktop
Old 08-25-2013, 08:24 PM
josehf34's Avatar
Well Now I got my engine rebuilded running again with the stock 2245 Holley but definitely the Holley is destroyed, my mechanic change the jets many times, adjust the mixture screws and cleaned the carb but when I'm using the car him turn unstable and the car shuts off so I think is time to swap for a 4 BBL
I bought this intake manifold http://www.ebay.com/itm/SB-DODGE-MOP...5f322a&vxp=mtr and someone recommended me this carter carb: http://www.ebay.com/itm/Carburetor-C...d12880&vxp=mtr
What about this carter? looks in good shape or is junk? I drive my Fury 74 like if I was an old man rarely I drive over 45mph but I want to get good MPG numbers remember this car is my daily driver.
Can be a good option to buy a rebuild kit like this: http://www.ebay.com/itm/CARTER-AFB-C...d88a6f&vxp=mtr ?
Old 09-10-2013, 06:14 PM
josehf34's Avatar
I got a question:
What kind of hardware Will I need to install the make the swap from the Holley 2245 to the Carter AFB 625?
The throttle linkage will fit?
Old 09-10-2013, 07:40 PM
You will need the 4 barrel TV linkage and bracket for the 4 barrel....
Old 09-10-2013, 09:18 PM
josehf34's Avatar
mmm sorry but I don't know what are those pieces. Can you send me a link from ebay or summitracing of a piece of this that fits in the Carter AFB 625?
But please remember I'm going to use this Intake http://www.ebay.com/itm/SB-DODGE-MOP...5f322a&vxp=mtr
Thank you
Old 09-10-2013, 10:09 PM
  #24
This looks like a very good one? I can send a copy of the instal instructions if you need them
http://www.ebay.com/itm/CARTER-4-BAR...f8cb15&vxp=mtr
You need a square bore carb to go with that manifold
Old 09-11-2013, 06:00 AM
  #25
This for a van...But you get the idea
Old 09-11-2013, 06:04 AM
  #26
This is for a Cuda / Challenger W/360/727
http://www.cuda-challenger.com/cc/in...?topic=83382.0
Scroll down the page....... To see the Dia.....
I would say your best bet of picking them up would be at a wrecking yard you e-bay. But get it for YOUR car and engine.
Old 09-11-2013, 06:33 AM
  #27
josehf34's Avatar
I'm not sure but I think this is a replica. If I'm right the Carter 9000 series end with the letter S and the replica ends in SA and the listed carb is a 9636SA
So this http://www.ebay.com/itm/Carburetor-C...d12880&vxp=mtr will fit in the posted intake? or will be a better choice this: http://www.ebay.com/itm/CARTER-4-BAR...f8cb15&vxp=mtr
I already bought a carb paint to restore the carb
Old 09-12-2013, 09:54 PM
  #28
josehf34's Avatar
Thank you for all the help, I really appreciate all the assistance and patience I had received from forum users
Today I read in hotrodders forum that some 2BBL carburetor throttle linkages fits in some 4BBL carburetor but I'm not sure about this. I take this two pictures of my holley linkage to see if someone can confirm if this will fit in the new carter carb.
In other forums some users recommend this two kits for the swap process from 2bbl to 4bbl
http://www.ebay.com/itm/Lokar-ACA-18...220388&vxp=mtr
http://www.ebay.com/itm/New-Lokar-XS...d89690&vxp=mtr
What of these items must I buy to do the swap?
I'm very confused I thought the swap would be easier
EDIT: I miss something: Will be possible to use the stock A/C compressor with the new intake? or should I buy a new mounting bracket that fits in the new intake?
Attached Thumbnails Help me to buy a carburetor-20130912_213453.jpg   Help me to buy a carburetor-20130912_213501.jpg
Old 09-13-2013, 07:28 AM
  #29
Looks like you have it all......
Only thing you might need would be the bracket that's on the intake. Everything else should work fine.
I think if you use the 2 barrel carb bracket the arm for the TV linkage is just not straight but it will still work.. It just looks funny....
Old 09-14-2013, 05:40 AM
  #30
josehf34's Avatar
Here's some good news for me
What of these brackets would be a good option? http://www.summitracing.com/search/p...ntake-manifold
So Can I use my stock kickdown linkage or should I buy the Lokar Linkage?
Quick Reply: Help me to buy a carburetor
