High School budget 318 build
I have a 77 D100 that decided it wanted to become a two stroke and it was just sluggish so I am rebuilding the engine. I would like some input on building the engine, I want a little bit more power out of it and I think I might just get the factory heads polished (I've heard that porting the factory heads ruins bottom end, anyone got any input on the truth of that?) I am on a somewhat tight budget because I'm still in high school but I do have some money saved up. I think I will use a 340 intake that I have laying around instead of buying a new one.
The parts I am considering buying are;
The Hughes Engines RV cam kit and the advanced curve distributor Hughes Engines RV Cam Hughes Engines Fancy Advanced Curve Distributor
Hooker Long Tube headers Hooker Headers 5902 Competition Long Tube Headers 318-360 MOPAR Small Block V8 - JEGS
And this rebuild kit Enginetech RCCR318F Rebuild AMC Chrysler 5.2L 318 – AMS RACING
Anyone have any suggestions for connecting rods?
I'm not very experienced with engine building or parts choosing so I would greatly appreciate any sort of advice/help on finding the right parts for this.
My Personal Opinion would be to work with a good known local machine shop / Engine Builder in your area.
Go over the plans with them on you engine build and i am sure you can come up with a well put together long block assembly for your truck that you can budget for.
If not you may wind up with parts you cant use of return.
Books are always good knowledge, Very helpful at times.
Its good that you are in a vocational program !!!!
Not sure what that consists of ? But I hope you are learning a lot from it. The learning never ends in the automotive industry. Its always changing every year. But a good education as a foundation is the best thing you can start with !!!! And lean as much hands on as possible while your there...
On a side note, One of the best books that i ask young folks to invest in, as a beginner, is the book " Automotive Encyclopedia" and also anything dealing with ASE Certifications.
https://www.google.com/search?gs_ssp...hrome&ie=UTF-8
Talk to you instructor and a local machine shop for what you want to do as an upgrade and or rebuild. Then you can get a good feel for what its going to cost you to complete your venture...
Now on to questions and answers.... Cheers
From venture comes disappointment or success. You want to avoid experimenting. Firing the performance parts cannon could lead to disappointment. Years back a speed shop did a performance build on a 318. They listed performance camshaft, heads and pistons used. I copied their success story and WOW!!! it worked. That 318 was a rocket ship. Just like a cooking recipe you need to have a balanced recipe for a good outcome.
RacerHog (04-12-2024)
Miner_Jeepy
01-31-2021 03:14 PM
fletchy38
08-05-2012 06:14 PM
