Intermittent knocking sound, '72 318
Old 12-04-2014, 06:31 PM
akers72dart's Avatar
I have a 1972 dodge dart swinger with a 318. and for weeks now I have had this knock that comes and goes. its heard from the engine compartment and kinda towards the drivers side. the motor is built up and has a pretty aggressive cam. I've had a feeling its in the valve train somewhere just based off what it sounds like but I could be wrong. any ideas on what it could be?
Old 12-04-2014, 10:18 PM
It's an unknown without more info.
Old 12-05-2014, 09:00 AM
I'm Kind of with Lynn..... But.. Pull the valve covers and check to make sure everthing is in order. Check the lash while your there also....
Old 12-06-2014, 11:10 AM
will do. thanks racerhog.
Old 12-06-2014, 05:49 PM
Run for a short time without belts.
Check the torque converter flex plate and bolts.
Have a look at the harmonic balancer for straightness, looseness or rub.
Turning crank back and forth can show any looseness or noises.
TurboDouche
06-24-2013 09:17 AM
profdel
06-13-2012 10:34 AM
stazja01
05-18-2011 02:41 AM
hippo204
08-17-2010 01:10 AM
David Blair
03-14-2010 04:48 AM
Quick Reply: Intermittent knocking sound, '72 318
