new yorker with 440cid jerking and backfiring in carb
#31
now i know its not anything but carb problem going too lean.
i got it working good when i put back the original floats but after a few weeks working good it started to smoke black pretty much so i thought the orginal floats could be bad and sink, so i put new ones and same adjustments with the first ones.
and now the problem is back and i dont know whats causing it to go lean after the choke closes :\ can the primary well seals cause this if not put in right?
I wouldnt want to open that carb again until i know what should i do, cause it very annoying after like 6 times.
Or could it be just the basic adjustments? ive tried adjusting metering rods and idle mixtures, riching metering rods eliminates the backfire, but it still wont drive good until pressing lot of gas.
Accelerator pump works good, checked that it squirts nice and i can feel it when pressing the gas as it starts going fast when accel pump squirts but after that it just starts to slow down.
#32
Black Smoke..... Is the choke stuck closed?
Also look down the throat of the carb when running and see id you see fuel dripping?
What carb are we talking here... I guessing it's a 2 barrel Carter?
#33
Sorry for my bad english, i meant that when the car ran good it was putting black smoke and it was fixed by putting new floats, but now it goes too lean when warmed up.
Those new floats are adjusted same as the old ones, so i dont think theyre the problem for lean mix, what else could cause it go lean after warmup?
Its 4bbl Carter Thermoquad
#37
Thats a good universal T.Q. Carb....
I would say open the Idle air mixing screws up about 4 turns from all the way closed. That should richen it up enough to not go so lean after getting warmed up....
#39
Could it be the wrong vacuum source for the dist , its not getting the vacuum from carb but from manifold.
Or is the vacuum source so important?
The car had run good one time after rebuild for couple months :S
#42
Dose it look like this one? If so we might be on to something....
http://www.ebay.com/itm/1977-77-440-...0e5c6c&vxp=mtr
#44
Ok..Carl... I think it's coming clear....
Dude... I should have called you....lol Sorry...
That is a lean Burn carb!!!! They suck!!!
But..... Here is what we can try....
(I'll have to go out to the shop and look to see if i have how the Dist. Vacuum advance is hooked up for these... I'll try to do that today, and get back to Y'all)
Unhook the Dist. Advance for now..... Set the timing to like 12*BTDC / 750RPM
The Vacuum source that was for the Dist. Hookup.... Hook it to the little nipple on the from of the carb, up on the top right "as your looking At the carb from the front of the car"
That is an Enrichment Circuit for those carbs... I think that will help with the popping your getting !!!!
Note: I'm not sure we can do anything with the Dist. Vac. Advance... I think when I look at the book...It's going to tell me that the Dist. Vacuum advance is controlled by the Lean Burn Control along with all the other switching B.S.....
#45
yeah its lean burn carb, and lean burn system has broken so someone has changed the orginal dist to a vacuum version so no electrical BS in there.
and the enrichment thingy is already hooked and its working
#46
ok....
So with the timing set @ 12* at Idle.....
The IE hood up to full vacuum now.....
The vacuum advance not hooked to anything.....
With with a timing light..... @ 2000 RPM... What dose the timing read?
#49
Hello! New to mopar and new to forum.
I bought a 77' new yorker few months ago and its awesome boat.
But now few days back it just suddenly started backfiring in carb and jerking alot when pressig gas.
It has the lean burn box in it, but i think someone has converted it or at least tried.
Theres the Orange ignition box, and ive heard it fails alot and causes jerking and backfiring,
So i changed it and ballast resistor to test, but did nothing.
Any ideas how i start checking and what?
Cheers
Cheers
#50
After driving it another year, i got a new carb.
I got a remanufactured Thermoquad from year 76, so no lean burn and it has the vacuum port and now car works great now.
One last question is that how do i adjust the Torqueflites throttle rod or whatever it is that changes the transmissions pressure? When i changed the carb i had to loosen up throttle cable a bit because it was too tight, but now the trans rod is too loose and it shifts way too early and slips when shiftin 2-3.
#51
Good to see you back and all is alot better....
There was a couple different types of linkage used... With out a picture of what you have, it's kind of hard to say..... BUT
Most of the linkages ether have a screw type or a Bolted slider type. If you search around here on the site you will find some pictures you can use...
But bottom line you just need to lengthen the rod for the T.V. to where it just touches the throttle stud...
Austringer
05-17-2015 02:49 PM
Idrivemopar
02-12-2012 07:26 AM
