SB or BB, Which will be more reliable?
Old 01-30-2014, 01:30 PM
  #31
Your heading back into the hi-performance area again.
Are you sure you want to go there?
Old 01-30-2014, 06:52 PM
  #32
josehf34's Avatar
Hi-performance area? I was hoping that a stroker can be build for street drive. If I'm wrong and a strocker cant be build as a street drive I will have to build the 360 so, which head, pistons and cam will be a good setup?
Old 01-31-2014, 09:44 AM
  #33
Sure, strokers are built for the street all the time.
Old 01-31-2014, 10:12 AM
  #34
demetri's Avatar
Originally Posted by josehf34
Guys I want to consider the posibility of stroke my 360 instead of replacing it with a 440. The saved money will be great to do other stuff to the car. But I've a question: What stroker setup can be build with a bore of 4.02", having low rpm great torque and smooth idle?
I don't have any experience with stroker engines and I had read some statements that appear to be myths, these are some:
-stroker engine will not last long than a non stroker engine
-stroker engine can easily crack the block
-stroker engine always has rough idle
-stroker engine works hotter than non-stroker
-stroker engine can only be build to high rpm applications
Are those statements true or not?
The basic approach of a stroker engine is weak, because it disturbs the bore/stroke ratio and con-rod to stroke ratio. One thing is for sure. Fuel economy will deteriorate compared to the stock engine.
Bronze_72newport
17
01-04-2014 08:54 PM
barry
02-20-2012 07:23 PM
Red Devil
08-09-2009 06:32 PM
Valcam
06-04-2009 11:47 PM
Doc
07-06-2008 11:10 PM
Quick Reply: SB or BB, Which will be more reliable?
