Slant 225
Old 10-09-2011, 07:58 AM
jcolbert's Avatar
Slant 225
I am looking at picking up a 71' Plymouth Duster. It is rust free and has original paint. It is in stellar condition and the price is right. I would like to eventually like to throw in a 340. Will a 340 fit on the same frame that the slant 225 is sitting on in the 71 duster? Obviously I will have to get different engine mounts, but will the 340 be able to sit on the frame? When I talked to the owner of the car, he stated that I would have to change the frame out to accomodate the 340. Is that true?
Old 10-09-2011, 08:20 AM
mr340's Avatar
'Tis true, the K-frame has to be changed to accomidate a V-8.
Old 10-09-2011, 08:42 AM
jcolbert's Avatar
That would mean I would have to unbolt the body off of the frame and then swtich everything over to the new frame?
Old 10-09-2011, 10:53 AM
mopardrt's Avatar
though easy to find a V8 K frame this company has what you need http://www.engine-swaps.com/Pages/Pr...ody.html#head1
Old 10-09-2011, 10:55 AM
mopardrt's Avatar
no there is no fram chrysler cars do not use frame they have sub frames the Engine cradle known as the K frame in mopar world unbolts from under the car
Old 10-09-2011, 11:09 AM
jcolbert's Avatar
with the A body conversion kit, all I would have to do is bolt that on to the frame and then basically drop the 340 in? ( I know i am oversimplyfing things, but in essence is that all I would have to do)?
Old 10-09-2011, 01:27 PM
mr340's Avatar
Can't tell you how the kits work, every V-8 conversion I ever did was done with a K-frame swap. It's not that difficult, the thing is basically only held in with 4 bolts.
Old 10-09-2011, 01:39 PM
jcolbert's Avatar
The duster i am looking at is a 1971 duster hemi orange with 2 white pin stripes numbers matching an has original paint. It also has the build slip. Is that a good deal for 2900?
All in all how much would I have into it if I dropped a 340 into it?
Old 10-09-2011, 04:48 PM
You need to change the trans too ! As far as a 340 ? I would be cheaper to get a 360 motor. It's an afternoon project to change the K frame esp with the motor out..
Old 10-09-2011, 05:56 PM
jcolbert's Avatar
Lets say if I were to pay a resto shop to put it in, what would it cost to do you think?
Old 10-10-2011, 09:54 PM
mopardrt's Avatar
Arm and a leg
cmetzbower
10-11-2010 12:27 AM
1966DartConvertible
08-06-2010 09:03 AM
carburetor472
09-02-2008 09:15 AM
hatboy2002
06-18-2008 10:05 AM
1980b100van
05-02-2008 09:53 AM
Quick Reply: Slant 225
