Tuning a 360
Tuning a 360
Hi there lady's & gents I have a 36 mopar & want to tune & over haul it I'm having the bottom end rebuilt I need to no wot cam I shoul use. Also as I'm now not going to supercharg or turbo it should I put higher comp pistons in it. Was going to spend money on porting & bigger valves & rockers should I buy after market heads . Thanks darren
Darren grosvenor (02-05-2014)
If you look up those numbers they will come up with the cam profile numbers and recommendations. One says it will work with a stock torque converter if your planning on running an automatic transmission, the other wants a higher stall T.C. so it won't stall or stumble at launch. What you plan to do with the car is all important, here are some order forms and you can see that every detail is asked for to get the power in the optimum RPM range for the application.
http://www.crower.com/media/pdf/cam_form.pdf
http://www.iskycams.com/pdfcatalog/2004-05/page216.pdf
