'62 727: rear pump/support check ball location
Hi,
I am rebuilding a Chrysler 62 727 tranny. When removed output shaft support from case / rear pump, a check ball fell off and now i cant reason the location.
Pic or link and other help is appreciated. Thanks.
I spent some time today looking for a breakdown but no luck.
thanks for your time guys.
it is aluminium case. push button shifter. drum brake at end of tail housing.
my atsg book does not recognize a rear pump model.
if your documentation does not show a check ball back there i guess it is not necessary.
please comment if some of you have a better view.
i appreciate your help. thanks.
I'm at a disadvantage because I've never worked with a virgin 62 to 64 trans, everything I've had my hands on was I later trans modified to work with the cable shift.
I looked again this morning with no luck.
Iowan (06-05-2019)
Thanks for coming back and sharing your findings. 👍
I also Did not find the ball for that area... Strange !!!
Glas you found where it went. And thanks for reporting back...
Hope the trans works well when you get it back in. I know folks have shifter issues. Hope you dont run into those !!!
catchmeifyoucan
02-09-2014 05:17 AM
2002ram440
04-21-2010 11:20 AM
