727 problems.
727 problems.
So I figured I'd ask before diving in and rebuilding my whole transmission. It is in drive regardless of what gear I shift it into. If it's in a forward gear it goes forward, if it's in neutral it goes forward, if it's in reverse it tries to go forward and backward at the same time, and if it's in park it tries to go forward but the parking pall holds it still. Should I rebuild or is there something less intense that's gone wrong. I've never had this problem with any other car so this is my first time troubleshooting something like this. Hope to get an answer ASAP so I know what to spend my money on. Thanks for any advice!
sounds like the rear clutch is dragging. I would change the fluid and filter first to see if it helps. get a good tranny service manual like ATSG's.
good luck,john
good luck,john
Colorado_Fury (03-03-2014)
