727 TF In 72 dodge d100 leak?
Old 10-18-2011, 02:30 AM
72D100dodge's Avatar
Where would be the most likely spot where the tranny would be leaking. I have asked a few people and I heard that maybe the shift shaft seal was leaking...I'm no expert so any ideas?
Thanks
Old 10-18-2011, 03:20 AM
mr340's Avatar
It can leak from anywhere there is a seal or gasket, Rear seal, linkage point, speedometer assy,pan gasket, front seal. I had a '72 charger that leaked from a crack in the torque convertor hub, this happened more than once with that car. The only real way to find it is to get under there and look for it. Clean the trans up real good, and look for wet spots.
Old 10-18-2011, 04:00 AM
okay thanks i'll do that this weekend for sure. I appreciate it.
Old 10-18-2011, 06:13 PM
Here is a picture I hope will help: http://www.moparsbymosher.com/specs/...ansmission.htm
Old 10-18-2011, 09:54 PM
Mother Mopar has a pan gasket Used on later 518 ? Looks like a hard plastic. EXCELENT gasket & won't leak, forget those cork gaskets !!!
Unusual leaks are usually the shifter seal. When the bushing in the valve body gets worn It causes the seal to go also from the movement
Old 10-23-2011, 02:58 PM
bboogieart's Avatar
Find anything yet? Best to clean with a good solvent. Wash down with brake Clean and let dry. Powder the trans with baby powder and run it for a short time the leak should reveal itself.
As said; there is a seal or gasket, Rear seal, linkage point, speedometer assy,pan gasket, front seal.
Also check the tail shaft housing for a gasket, and under one of the tail shaft bolts, (bottom right looking from the back) there is a pivot pin that is captured by the tail shaft it self. This pin has an o-ring that can fail.
Laura Cullen Reynolds
11-24-2012 02:04 AM
furyaboveall
10-02-2010 08:04 AM
jar84203
09-10-2009 01:30 PM
mopard100
10-06-2008 02:38 PM
alwaysamopar
07-11-2008 01:33 AM
Quick Reply: 727 TF In 72 dodge d100 leak?
