Dodge 360 Water Leak
I have a rebuilt 360 I have dropped into a 73 Charger SE. I am having an issue with a water leak. On the right (passenger side) front exhaust stud, apparently there is a water port. I keep having a leak. I was told to replace the stud, which I did. Was told to put teflon tape on it to stop leak. I did, but it didn't stop the leak. I was then told to put high temp silicone on it. I did this too but still have a leak.
Any suggestions?
Any suggestions?
Front and rear stud locations on both sides enter the water jacket. I had the same problem on my Aspen. I got new studs and wrapped the crap out of them with teflon tape and they stopped leaking. If you never want to take them out you could drain the sytem and mix up some JB Weld and pooky the stud and hole with it, let it dry then fill it up again.
fastcoauto
08-16-2012 02:08 PM
72D100dodge
10-23-2011 02:58 PM
