Brake Master Cylinder Push Rod
Old 10-17-2011, 06:56 PM
Jim Brown's Avatar
Anybody know where I can get the correct brake master cylinder push rod that goes to the brake pedal for a 72 Cuda with a manual transmission and manual brakes? I converted from an automatic transmission and the push rod is too short.
Old 10-17-2011, 08:32 PM
Transmission swap has nothing to do with the brakes
Old 10-18-2011, 06:10 PM
Jim Brown's Avatar
Thats's what I was thinking but my push rod that hooks to the brake pedal is 1/4" too short.
Old 10-18-2011, 10:01 PM
samuelcosmo76's Avatar
so wait. you changed the transmission. did you change the master cylinder too? whats the difference?
Old 10-18-2011, 10:14 PM
One of the Co that offer disk brake kits should be able to help you , Or find any A, B body with manual brakes for the correct rod
Old 10-19-2011, 04:35 PM
Jim Brown's Avatar
I got the brake pedal, clutch pedal, hanger and rods from a 1970 Challenger with power brakes. The brake push rod from the Cuda manual brakes is too short to fit the replacement pedal
Old 10-19-2011, 09:14 PM
So start checking the junkyards... An A body would probably be easier to find with manual brakes... Still sounds strange As I remember the Power Brake pedal linkage is attached to the booster ??
Pedal height will change from power to manual
40p10fury
01-14-2015 04:28 PM
mytracy
12-07-2010 08:11 AM
jar84203
10-12-2010 05:07 PM
Imperial1973
09-05-2009 10:17 AM
buttslapper
10-01-2007 06:32 AM
Quick Reply: Brake Master Cylinder Push Rod
