Master cylinder and booster install question
Old 05-17-2011, 08:06 AM
bboogieart's Avatar
I am getting ready to install all new brakes befor I drop in the new motor.
1968 Chrysler Newport.
1st question is; do I bench bleed the cylinder alone or as a unit with the booster.
2nd question; Do I need to do anything with the push rod from the booster, such as adjust it or, pull it out some, or just bolt 'em together?
Thanx in advance.
Old 05-17-2011, 03:50 PM
MrOldart2U's Avatar
Alone
Thanx in advance.
No not NORMALLY... Just bolt em together.
Old 05-17-2011, 04:46 PM
pjmopar's Avatar
Bench bleeding is a must or you will not have a brake pedal,i would measure the length of the rod and be sure it is very close to the inside of the m/c.when installed.then you can install in one peice.Then bleed each wheel cylinder starting with the wheel furthest from the m/c
Old 05-19-2011, 04:56 AM
bboogieart's Avatar
Thanx guys,
mytracy
12-07-2010 08:11 AM
jar84203
10-12-2010 05:07 PM
Imperial1973
09-05-2009 10:17 AM
Mixmastermerrill
10-20-2008 09:22 PM
buttslapper
10-01-2007 06:32 AM
Quick Reply: Master cylinder and booster install question
