Rear brake question
Old 01-07-2019, 01:37 PM
SixBanger's Avatar
Rear brake question
I recently replaced the shoes of the rear drums. With normal use everything seems to work fine. However, the right rear brake seems to block quickly with a somewhat more abrupt braking (raining conditions). However, after releasing the brakes, it does not block. Even after longer driving you notice that the brakes bit more bite.
What could be the cause of it?
Thanks!
Alex
Old 01-07-2019, 02:02 PM
I'd first look at adjustment.
Old 01-07-2019, 02:03 PM
There is a primary and secondary brake shoe, if you get them mixed up sometimes that wheel will not work properly.
Old 01-07-2019, 03:03 PM
SixBanger's Avatar
The adjustment wheel doesn't look great. But maybe it could be something else.
I am convinced that I have replaced the primary and secondary. One piece at a time.
Old 01-07-2019, 04:50 PM
The short shoe should be on the front side or the leading side.
Old 01-07-2019, 04:53 PM
I would remove drums and adjust out by hand so they slide on with the same resistance then take it for a drive. If the star wheel and adjusting lever are worn take a file to them to square up and sharpen them.
Old 01-08-2019, 05:44 AM
SixBanger's Avatar
Thanks! I would remove the drums and file the star wheels and check the fitting of the shoes.
Old 02-04-2019, 12:57 PM
SixBanger's Avatar
I did replace the adjustment and spring setup on both sides. The adjustment screw-lever seems working better. But I notice that pressing the right drum on the shoes does take some effort. This was easily done on the left side.
After some driving and hard braking the right wheel slips.
Would be the right wheel cylinder need to be replaced?
Old 02-04-2019, 01:02 PM
Is it leaking fluid at this point?
Old 02-04-2019, 03:07 PM
SixBanger's Avatar
No leakage anywere only lot of dust
2003 dodge
02-17-2019 03:37 PM
gbm97
07-21-2017 05:50 PM
dsikkema
11-13-2014 01:20 PM
a.johansson84
02-19-2014 02:40 AM
rbrother
01-19-2010 01:38 PM
Quick Reply: Rear brake question
