Strange leaf spring?
Old 12-17-2016, 05:49 AM
1970ccc's Avatar
What is this bottom leaf spring for? Is it stock? Will the car go up ur down if removed? It's on a '70 Stock 318 Belvedere.
Old 12-17-2016, 06:30 AM
1970ccc's Avatar
The rear of my car is also lower on that side.
Old 12-17-2016, 06:41 AM
Its a add a leaf or helper spring load leveler what have you, I would look to see if you have a broken leaf.
Old 12-17-2016, 07:10 AM
fivepoint's Avatar
Its a helper spring. My dad used to put them on to fix weak springs. If your car is setting low, it may be time for some new springs.
Old 12-17-2016, 07:14 AM
It's probably time for a new pair of springs, you should also check the front torsion bar crossmember for rust.
Old 12-17-2016, 08:36 AM
Man these guys are good !!!!!!!
I agree... Time for a new set of suspension items front to rear....
Old 12-17-2016, 11:45 AM
1970ccc's Avatar
Awesome. Thanks to all. Looks like Summit has them for $109 each. Ron
Old 12-17-2016, 12:33 PM
fivepoint's Avatar
If you have plans to put a big block engine in it, get the heavier springs and torsion bars. Don't let anyone talk you into installing longer rear shackles to make up for the weak springs.
1970ccc (12-17-2016)
Old 12-17-2016, 12:40 PM
Make sure it comes with bushings.....And don't forget a new set of shackles and the bolt kit....
Old 12-17-2016, 01:09 PM
1970ccc's Avatar
I will go with the heavy duty. I assume you just put jack stands under the rear frame and use the jack to move the rear end up and down as needed?
Old 12-17-2016, 01:37 PM
Yes, change one at a time you will probably need new U Bolts.
Old 12-17-2016, 01:42 PM
Dont skip looking over the crossmember where the front torsion bars go into the frame. They are prone to rust allowing the bar to turn and car to sag on that side.
Old 12-17-2016, 05:08 PM
fivepoint's Avatar
Order your parts and start shooting the nuts and bolts with penetrating fluid. Spray them every other day and by time the parts arrive, disassembly may be easier.
Old 12-26-2016, 06:04 AM
05dakota's Avatar
espo.com
Old 12-26-2016, 10:00 AM
Originally Posted by 05dakota
espo.com
Great people to deal with....
Old 01-29-2017, 08:26 PM
BigBubba's Avatar
Those are helper springs. They will help to lift the car for more tire clearance and eliminate some tire hop.
GG1
10-16-2015 05:58 AM
70newport
01-03-2015 11:58 AM
70newport
03-17-2013 01:23 PM
72sat
12-12-2011 06:15 PM
phatdak18
03-15-2010 09:19 AM
Quick Reply: Strange leaf spring?
