66 Monaco Ignition convertion issues
Hey all
I just switched over to electronic ignition on a 66(383) dodge Monaco convertible that I just inherited from my father and trying to get it started.......no luck
I have a proform 66993 conversion kit installed. I checked that there was 12v going to the ECU(Blue wire) and yes. I connected blue wire to one side of the ballast resistor(Key in run position side)
I checked the voltage at the coil with the key on and got 6V? Shouldn't it be 12V? I have black wire from ECU connected to the (-) of coil as per wiring diagram that came with KIT. I ohmed out the coil and got 1.6ohms across(+) and (-) and 10500ohm between (-) and output to distributor.
I lined up the timing marks and insured she was at TDC on cylinder #1 and lined up the distributer to plug wire 1. Firing order is correct
I also connected a jumper wire from the negative of the battery to the mounting screw of the ECU to insure it was not a grounding issue.
SO WHY 6V? BAD ECU?
I'm a newbie at working with car ignition systems but have a good electrical background.
Any advise is greatly appreciated.
cheers
Glen
SO WHY 6V? BAD ECU?
cheers
Glen
65Monaco
11-09-2014 09:43 AM
labradorian70
10-08-2014 12:21 PM
