69 B body Tail light Dash lights Inop
Old 04-17-2017, 09:33 AM
Eltigrez's Avatar
Here is the lastest problem I currently have no tail lights, instrument lights, marker lights or cigarette lighter. I have read through some of the posts regarding this issue. I do have power to both sides of the 20A tail light/cig lighter fuse. My brake lights, headlghts, flashers and signals all work. Any suggestions????
Old 04-17-2017, 05:54 PM
Pull the fuse block and trace the power feed wire... I beet you will find that it lost its power from the source.... That wire might run threw the firewall. Check it good..
Keep us posted...
Old 04-17-2017, 07:07 PM
Eltigrez's Avatar
Keep us posted...
If I have power to both ends of the fuse. How can the circuit not be powered?
Old 04-17-2017, 07:11 PM
Eltigrez's Avatar
Keep us posted...
Also, the instrument lamp fuse is not being powered.
Old 04-18-2017, 06:02 PM
Sorry... My bad... I read it wrong....
Sounds like it might be a issue with the headlight switch or the dash panel switch.
I think it goes from the fuse to the dash panel switch first. Check to see if you have power up to that point?
AliceSML79
08-22-2014 03:28 AM
1966charger
04-22-2012 08:27 PM
mach3107
02-09-2011 10:46 AM
MARTY566
07-18-2008 02:36 PM
Quick Reply: 69 B body Tail light Dash lights Inop
