77 Tradesman Insrument Cluster Lamps
Old 12-29-2018, 12:24 PM
Timbo's Avatar
Hi again folks, I've been quiet for a while - finally found a bush for my steering column and got it reinstalled. The original column switch wiring had been cut, twisted and taped! Not the best - so I used crimped bullet connectors, a much neater job. Please note the connectors need to staggered to enable the cowling to sit nicely.
Anyway, after doing all that I noticed my lh blinker on the dash wasn't working and so removed the dash and found 4 bulbs blown, the cluster push in types. What I wanted to know is what each of the bulbs do? I get the blinkers, the high beam at the top, but what do the rest do? I also have a bulb - loose on a long wire, which tells me I'm in park or neutral, whereabouts should that be on the cluster?
All replies greatly appreciated.
Timbo.
Old 12-30-2018, 10:46 AM
Post up a photo Tim.... Good to have you back...
Old 12-30-2018, 11:21 AM
Timbo's Avatar
Thanks RacerHog. Will do, be after NYE now . . . Wish all of you members a great 2019 from us lot across the pond! 🍾🍾🍾
Old 12-30-2018, 11:26 AM
You start just a bit earlyer there, have a safe holiday!
Old 12-30-2018, 11:56 AM
Timbo's Avatar
We do yeah, my pal in Australia gets it first! We start in just under 24hrs! Thanks Lowan, you stay safe too . . . 👍🍾
Old 12-30-2018, 01:51 PM
That's Iowan from the state of Iowa U.S.A. thank you very much. 🙂
Old 12-30-2018, 02:16 PM
Timbo's Avatar
Ooops! Sorry Iowan! Thought it was an lowercase l, my apologies sir! Have a great 2019 👊👍🍾
pascualindio
02-23-2020 10:00 AM
DANE
09-12-2018 11:29 AM
01-04-2017 08:03 AM
speedog24
07-02-2014 05:31 AM
tealfoster
03-10-2009 07:15 PM
Quick Reply: 77 Tradesman Insrument Cluster Lamps
