Denso Alternator on 440 Big Block Mopar
Old 05-24-2014, 07:45 PM
ykf7b0's Avatar
Is anyone using a Denso alternator on a big block Mopar? If so, which one are you using and which brackets worked for you? Also, externally regulated or internally? Thanks alot!!!!
Old 05-25-2014, 06:02 PM
moparted's Avatar
had the bracket from mancini, it broke the case on alternator, not enough suport. I went back to stock
Old 05-25-2014, 08:21 PM
ykf7b0's Avatar
Were you using 3 wire or 1 wire alternator? If it was 3 wire, which one?
Old 05-25-2014, 09:31 PM
No matter which one you use you need to eliminate it going though the alt gauge
Old 05-26-2014, 03:12 AM
Mr.4spd's Avatar
Mid 90s alt is too deep for stock location (3/4 ton anyway), at this point I lost interest. Curious if the stock regulator would work with it.
Old 05-31-2014, 08:36 PM
ykf7b0's Avatar
I just bought myself a Denso 210 0138. I have not installed but the mounting ears do not look much different than stock. It might be that the factory brackets will work. Some mods may be necessary. ?
Old 06-01-2014, 07:16 AM
I think Jegs sales a Denso Mounting kit for the big block Mopars....
If your trying to mount it to a front motor plate, thats a little harder, takes some fab work...
ykf7b0 (06-01-2014)
Old 06-04-2014, 03:25 PM
ykf7b0's Avatar
I now have the Denso mounted and the factory alternator brackets work great! The alternator is all the way out on the lower adjusting bracket and belt is tight for now but a shorter belt might be needed later. I have upgraded wiring and ammeter is bypassed. This thing charges like no other! 14.2 at idle with all things powered up including headlight on bright! It is a wonderful upgrade!!!
Old 06-04-2014, 04:26 PM
Post a Picture if you get time.... Show us what you did !!!!!
Old 06-18-2014, 04:19 PM
ykf7b0's Avatar
I have yet to figure out how to post a picture. I don't have photobucket. Help needed!
Old 06-18-2014, 05:52 PM
One 'joint' you can use for occasional free photo posting is
http://tinypic.com/
Sometimes there is, sometimes not, a "nag" screen. Hit browse, which opens your computer, select the location and file you want, and upload
I don't remember if it automatically resizes or not, most websites limit you to 600X......pixels or 800X.... pixels.
ykf7b0 (06-19-2014)
Old 06-19-2014, 04:28 AM
ykf7b0's Avatar
[IMG]http://i61.tinypic.com/300xkjp.jpg[/IMG
Not in great detail but here is what I did.
Old 06-19-2014, 04:33 AM
ykf7b0's Avatar
One more. Thank you 440roadrunner!
Old 06-19-2014, 07:40 AM
Your through bolt is going to BREAK THE ALTERNATOR. There MUST be a spacer between the two alternator ears to take up that space and give something "solid" for the bolt to tighten against
The shiny split spacer is designed to move a tiny bit upon tightening the bolt so that "things" equalize and no strain is placed between the two ears. So once you get belt alignment "happy," and everything lined up to suit, you need to measure that space, and fabricate a spacer. With no idea of what that might be, you may or may not be able to cut down a factory one used for so many many years on the original mount
Now, you can help ME, LOL. What specific "Denso" are you using? Brand, part no, year model it's off of, etc.
(Using the word "Denso" is just like saying "General Motors." It's pretty generic)
Old 06-19-2014, 08:40 AM
ykf7b0's Avatar
I knew I was going to get comments on the lack of a spacer and I will be working on that. It is not really tight (see lock washer in photo) at this time so little strain is forced on those upper ears, however the adjusting bolt down low is nice and tight and retaining all of the tension. The Denso alternator is 210-0138. Thanks again!
Old 06-19-2014, 01:39 PM
Thank you. Didn't know if you "were aware." I still run stock Mopar "square back" but have been thinking of going a little more modern
By the way, "way back" in about 75, before Al Gore invented the internet, LOL, I put a Delco integral unit on my 340 which was in my old FJ-40 Landcruiser. Not long after that, I put a Warn "wench" on the front, and (I worked in a parts store) scored one of the late seventies "big frame" 100+ amp Mopars which only needed brushed and bearings.
The Delco came OFF!!! The big Mopar would bury (I had a SW 100A meter) the ammeter
pipdog69
03-13-2012 11:01 PM
74bbroadrunner
03-13-2012 08:19 PM
68satellite
05-23-2009 05:33 AM
Brent1960
05-17-2009 04:25 PM
mahd
04-02-2009 09:05 AM
Quick Reply: Denso Alternator on 440 Big Block Mopar
