Drivers side window regulator assembly 70 RoadRunner
Old 10-24-2015, 05:05 PM
WI70rr's Avatar
I am in need of one my window is a bear to put up or down. Any leads would be appreciated. I have googled the heck out of this an nothing....
Thanks
Old 10-24-2015, 07:00 PM
Check all the felt in the channel and make sure it is in it's place.....
If all is good there, lube the felt and channel with some silicone spray.... Also lube the window regulator with some spray lubricant.... That should help it a lot. Also make sure to lube all the rollers and channels..... And dont forget to do the vent glass hardware also.....
Old 10-24-2015, 10:00 PM
WI70rr's Avatar
She is pretty well gone looking for a new one.
Old 10-25-2015, 12:09 AM
On several cars I have taken the clutch mech or what you call it from another reg to fix a hard to turn one
Old 10-25-2015, 08:18 AM
http://www.classicindustries.com/sho...arts/?q=mm1088
fletchy38
06-16-2012 09:31 PM
fletchy38
06-16-2012 07:37 PM
moparjohnson123456
06-14-2011 01:36 PM
68 Sat
03-29-2009 03:56 AM
1969GTX
04-05-2008 06:20 PM
Quick Reply: Drivers side window regulator assembly 70 RoadRunner
