"Start" circuit wiring
Old 04-07-2020, 05:24 PM
rhoole93's Avatar
I'm getting ready to fire up the new engine the only issue I am having is getting juice to the coil during cranking. I have power to the coil when the key is at the run position.
What is the proper way to get 12 volts to the positive side of the coil during cranking? Can I simply add a separate wire from the "start" position on the ignition switch and run it straight to the coil? Or should I splice into the yellow start wire on the starter relay and wire that to the coil?
Truck was converted from TBI to carb a few years back, and I cobbled the wiring together to get it running after the conversion. I want to make sure its done right this time.
Old 04-08-2020, 04:31 AM
I did this awhile back and used a relay, start from key to power the relay coil and battery voltage through contacts to coil. I also bypassed the computer and put in an older alternator and voltage regulator, the regulator was in the computer and needed inputs I had removed to operate. This was in a '90's pick up truck, good ol' DOUG E.
usedknobby
06-21-2013 08:33 AM
ssdart225
02-25-2011 05:18 PM
will d
12-16-2009 05:51 AM
64fury
07-07-2008 05:11 PM
raceware
05-16-2008 04:50 AM
Quick Reply: "Start" circuit wiring
