74 plymouth duster front end issues
Old 12-20-2012, 09:51 AM
shabe1's Avatar
hi everyone i am new to this . i have a 74 duster almost redone but drove it around my driveway and front end dropped and headers hit the ground. i put it on my lift and got new tortion bars backed it out started driving and it dropped again and that is with the tensioning bolts all the way in. can anyone help me thank you
Old 12-20-2012, 11:55 AM
I would suspect you do not have the control arms fully extended with the weight off when you are installing the torsion bars. Shocks disconnected too!!!
Old 12-20-2012, 12:03 PM
shabe1's Avatar
The weight was off but no I did not disconnect the shocks
Old 12-20-2012, 01:14 PM
did you have the front end disassembled ? so unless you put it together wrong ???
Old 12-20-2012, 04:13 PM
shabe1's Avatar
No I did not have it apart it was fine than one day it dropped and I put tortion bars on it and it raised me a little but not enough
Old 12-20-2012, 04:56 PM
Chryco Psycho's Avatar
Left & right torsion bars are clocked differently as well make sure the even # bar is on the right / passenger side , left drivers .
I agree the arms have to be lowered all the way down before the bars are slid into place as well . Either could be the problem
Old 12-20-2012, 04:59 PM
shabe1's Avatar
Ok I will check in the morning thank you
Old 12-21-2012, 10:05 AM
shabe1's Avatar
How do I know if its the even # bar is it stamped somewhere
Old 12-21-2012, 08:56 PM
on the end of the bar it should have a 3 digit part # it is 7 digits but only has the last 3 on the bar & may have L or R in the end also
Old 01-09-2013, 12:05 AM
70DartMike's Avatar
Could your tension bolts be stripped? You could be tightening them down, and then when you drive, they loosen off, allowing the car to drop.
Old 01-11-2013, 09:04 PM
shabe1's Avatar
No the bolts are still tight with plenty of tention on them. It's all of a sudden it's not a gradual drop and my car is still on the lift but in down position and 220 to the motor quit so have not been able to look hoping to fix it this weekend thanks everyone
Old 02-19-2013, 08:36 PM
shabe1's Avatar
fixed it
You were right I had a torsion bars switched right was on the left and the left was on the right I switched them and they work great thank you
Old 02-20-2013, 01:57 PM
pro-tech's Avatar
Good job Chyrco way to zero in on the problem.
Greghar23
07-04-2016 07:05 PM
fluffoffal
10-09-2012 03:53 AM
bruger
07-16-2010 10:14 AM
theironman
02-06-2010 10:08 PM
smallxfires
01-17-2010 02:36 PM
Quick Reply: 74 plymouth duster front end issues
