FOrd 8" into a 72 dodge dart
Old 03-07-2011, 11:20 AM
72swingage's Avatar
I heard that an 8" ford from an early 60s mustang would bolt right up but just want to confirm that.
Old 03-07-2011, 12:28 PM
ryan's Avatar
why???????
Old 03-09-2011, 07:57 PM
theomahamoparguy's Avatar
yes it will. almost exaactly the same width. and you can get it with a 4.5 bolt pattern. 65-66 mustang or falcon etc. Good for a slant six or 318 project.
1967 is about 3 inches wider
Old 03-10-2011, 01:27 PM
72swingage's Avatar
Oh ok, thanks for the info theomahamoparguy! I have a friend that has an 8" out of a 66 mustang laying around so im gonna hit him up for that thens. Reson im asking ryan is i epically blew the 7 1/4 rear end in my dart a couple of days ago im in need of another rearend. I checked out the 8 1/4 dodge rear end but i just dont like the C-clilp design and non taperd bearings. I like hauling *** alot on curvy roads and putting alot of side loads on a C-clip design rear end, thats just asking for trouble and trying to find an 8 3/4 for an abody its redonkulous!
Old 03-14-2011, 10:22 AM
72swingage's Avatar
just finished up bolting the rear end in, FITS nicely, problem now tho is the u joint! do they make a conversion u joint to adapt the dodge driveshaft to the ford rear end and if so what is the part number for it?
Old 03-14-2011, 02:57 PM
ryan's Avatar
Im just not a fan of ford stuff in mopars. Im sure that you could take the driveshaft to a shop and they could cut off the end and weld on a new end with the rite u joint
Old 03-15-2011, 02:25 AM
I know that there are adaptor u-joints out there but where I'm not too sure. You might want to try a place like Tom Woods Shafts.
Old 03-24-2011, 04:28 PM
72swingage's Avatar
ok finally i got the u joint set in place, had to do alot of running around but finally found it at a local drive shaft shop part # was the 2-3100 from the neapco brand, its working great now so its all good to go!
Old 05-27-2011, 09:00 PM
duster_066's Avatar
Then this means that a 9" from an early Stang will bolt into an A-Body...right?
76spiritof764speed
08-16-2018 12:12 AM
1966DartConvertible
01-17-2012 07:01 PM
1966DartConvertible
08-05-2010 07:58 PM
mystarcollectorcar.com
04-16-2010 03:42 AM
userofme
04-07-2008 12:34 PM
Quick Reply: FOrd 8" into a 72 dodge dart
