Im having carburetor problems???
Old 12-08-2008, 02:36 PM
Commando's Avatar
Sounds to me like you have a vacuum leak. Check all your hoses that go into the carb, the hose from the pcv valve (comes out of your valve cover and goes into your air filter), and the hoses that go into the intake in the "christmas tree" looking thing with all the hoses. Did you switch the carbs, is there a gasket between the carb and the intake? Will the engine stay at idle if you just turn it on? If not, checking the hoses by spraying wd-40 or a carb cleaner will need two people, one to keep the car running, the second to spray the hoses and listen for a change in RPMs.
Commando's Avatar
Forgot to mention, Welcome to the forums.
Old 12-08-2008, 04:08 PM
holley's can be hard to tune. It does sound like a vaccum leak to me. Inspect all of your hoses.
Carter cards are basically the same as edelbrock carbs. same design and easy to work. You can get some with a small CFM but you may be better off having your's rebuilt or replace it with a reman unit.
welcome to the forum.
Old 12-08-2008, 08:10 PM
challenger's Avatar
like 78 says you need to be on your toes with a holly but once you get it tuned its an ok carb but im with everyone else on the vaccume leak
Old 12-11-2008, 06:29 PM
Crazy4Carz.Com's Avatar
Well almost all the spellings I have seen, and the correct one is "VACUUM". Yes, I sell Vacuum cleaners for a living, and Vacuum is correct.
And again X3 I concur, a leak.
Old 12-11-2008, 08:50 PM
72RDRNR's Avatar
what about idle set too low? thats the funny thing about carbs either you love holley or hate them. both are good carbs as long as you know what your doing. i think edelbrock/carter seem to be easier to work with.
Old 12-13-2008, 06:03 AM
Any update green machine?
Old 12-13-2008, 06:20 PM
challenger's Avatar
hey c4c i think you scared him away with the spelling thingy hehehehe and yes you are correct don't know what got into me
Old 12-14-2008, 04:09 AM
Commando's Avatar
Another one leaves after the first post.
Old 12-14-2008, 08:34 AM
Ya, and they never come back to check out the answers
Old 12-14-2008, 05:27 PM
challenger's Avatar
aaaaaaaaa thats ok even though they are one post wonderers it still gives us a chance to talk about it if we get into the same situations , my club always has things to say about them but in my book hopfully they will at least return some day and say hi again
Old 12-14-2008, 05:36 PM
hopefully
Old 12-15-2008, 06:11 AM
Commando's Avatar
A vacuum leak is pretty much un-metered air getting into the engine, so you also should check the carb gasket and the intake gasket, there could be leaks there.
Old 12-15-2008, 06:02 PM
challenger's Avatar
Hey Glad ya' came back Green and forgot to ask but did you change out your fuel filter ????? no gas means no power and i would take some carb cleaner and spray into your carb if its blackish looking while its running around 1500rpm's k and go from there its either gas / air / or timing issue and could be also plugs and wires ,,,, so much but you have to start some wheres and id go with the filter and clean your carb and adjust the fuel level on the holly and set the idle screws
Old 12-16-2008, 04:19 AM
Commando's Avatar
What kind of choke is on it, there could be an issue with that if you can't get it restarted.
Old 12-16-2008, 07:24 PM
challenger's Avatar
have you checked the fuel pump to make sure its pushing fuel to the carb, try and squirt some starting fluid in the carb while some one is turning it over and once it starts (if it does) keep squirting little at a time to see if it stays running
Old 12-17-2008, 03:38 AM
X2, I was going to say the same thing. You can also just remove the fuel line to make sure that you are getting fuel from your tank and to see if the pump is working properly.
Old 01-01-2009, 05:51 PM
Originally Posted by richinny
a bad EGR valve can cause a leak too.
I didn't think there was Exhaust gas recirculation in '76?
Old 01-03-2009, 12:16 PM
  #24
challenger's Avatar
Have you got it going yet green ????
Old 01-05-2009, 03:42 AM
  #26
are you sure that you are getting fuel to and through your carb? Have you tried to spray starter fluid down the carb as it is running to see if you can keep it running? Are you getting enough fuel to the carb?
Old 01-05-2009, 07:53 AM
  #27
Commando's Avatar
I know you said that you changed the fuel filter, but sometimes people put two in, also I would inspect the lines to see maybe there is a bottleneck somewhere. Do you have suction in the fuel pump?
Old 01-05-2009, 08:56 AM
  #28
make sure you installed the filter in the right direction. Trust me when I say it does matter. Don't ask me how I know.
Old 01-06-2009, 01:55 PM
  #30
Polaradude's Avatar
Iam just throwing this out there, hows the timing ?
Quick Reply: Im having carburetor problems???
