Master Cylinder Question
Old 10-08-2010, 10:10 AM
Member
jar84203's Avatar
I just replaced the proportioning valve on my 71 Duster and when I had all the lines disconnected, the rear bowl of the master started to drain, but not the front. Is it normal for the front to stay full when the lines are off? What keeps the fluid in, but not on the back? Thanks.
Old 10-09-2010, 12:17 AM
A.K.A Bob Dodge
1966sportfury's Avatar
mine leak if i take them off, was the front fuller than the rear? or maybe the front bail seal as a tigher fit
Old 10-09-2010, 03:30 PM
Member
jar84203's Avatar
Front and rear were both full. The rear actually emptied out and the front just stayed full.
Old 10-12-2010, 05:07 PM
Member
jar84203's Avatar
OK now I'm trying to bleed the brakes and I can't get fluid out of the rear wheel cylinders. When I hook up my pressure bleeder, I can get fluid out of the front bowl port, at the prop valve, but not out of the outlet of the prop valve. Any ideas? It's a brand new prop valve from Inline Tube.
Jim Brown
10-19-2011 09:14 PM
bboogieart
05-19-2011 04:56 AM
mytracy
12-07-2010 08:11 AM
Imperial1973
09-05-2009 10:17 AM
buttslapper
10-01-2007 06:32 AM
Quick Reply: Master Cylinder Question
