Transmission slip or something else?
Old 08-06-2013, 01:32 PM
75Duster360's Avatar
When i'm in 2nd and 3rd gear if i punch it to quick over 3500rpm it seems to be slipping/ starts chugging along and sputtering. I have a 4 speed from a 73 valiant.
if i give it a gradual acceleration there is no slip.
any ideas?
Old 08-06-2013, 02:42 PM
slade's Avatar
it spits and sputters? if ur clutch slips the engine will rev high really quick if its a spit sputter u may need plugs wires/ fuel filter carb cleaning.
Old 08-06-2013, 06:31 PM
Those are 2 sprite problems....
What Happens in 1 & 2 ????
Old 08-06-2013, 06:43 PM
Sounds more like a carb problem.
Old 08-06-2013, 08:01 PM
I agree about the carb, what carb is it?
To confirm find a place where you can try the same 3500rpm acceleration in each gear and record the results.
Old 08-07-2013, 12:17 AM
1st gear goes up to 5k rpm
2nd starts sputtering at 3300 rpm when i was going up a hill
3rd sputters over 3600rpm
4th sputters right away around 2800rpm
this is a ll when gunning it pretty hard
if i give it a slow gradual it will sputter and catch up and shake a little
thanks for the info.
got new plugs work the late shift so Im a late night poster.
Old 08-07-2013, 12:30 AM
Change the fuel filter too....
Old 08-07-2013, 06:09 AM
pro-tech's Avatar
I would do the cap, rotor, and wires with the plugs...Bill
Old 08-07-2013, 10:24 AM
I thinks its running out of fuel....
Fuel filter
Check fuel pressure.
Check fuel flow
Reset Float level
Just my 2 cents
Old 08-07-2013, 02:59 PM
Sounds like fuel starvation to me too. What type of carb? A fuel pump test may be in order too.
Sorry Bob I see you said that too. Dan.
RacerHog (08-07-2013)
Old 08-07-2013, 09:53 PM
thanks again its got an old fuel pump
Old 08-11-2013, 07:09 PM
Problem solved changed plugs all except 2 behind headers on driver side. Will get at them when I swap out headers tomorrow. Did notice a little sputtering on hills. What's a good 12v pump?
Old 08-11-2013, 07:58 PM
slade's Avatar
for fuel? theres no need to install a electric pump you can always install a high flow mechanical pump
ZombiePopper
03-30-2020 05:58 AM
pro-tech
24
09-03-2013 08:08 AM
kevinjmay
06-19-2013 05:55 PM
snaponbob
10-17-2012 04:34 PM
02-15-2010 11:07 AM
Quick Reply: Transmission slip or something else?
