1978 dodge power wagon fulltime parttime 4x4 swap
Old 04-11-2011, 02:29 AM
  #31
Very cool!
Old 08-28-2011, 08:19 PM
  #32
PireWagon's Avatar
78 d200... I jus got bought a 78 3/4 ton 4x4 4speed 318...I would like to switch out the full time front axle with one that has hubs I can lock out..what years front axles will work..what all wood I need to check ...input output shaft spline counts...etc.thx ..
also does this site have a classifieds section.. I plan on pulling off all the trim and getting rid of thought someone mite be interested ..thx for yer time
Old 08-29-2011, 02:44 AM
  #33
With that year truck, you should be able to get a manual locking hub kit from Warn and be all set. It's not hard to install either. The front axle should be a dana 44 with 19 spline outer shafts. Dodge did use what they call "Selectro Locking Hubs". it really depends on how your front axle is setup now.
Old 08-29-2011, 09:45 AM
  #34
PireWagon's Avatar
The front hub is currently fulltime hubs I called warn today and he explained to me they only deal with 80-93 _ trucks..
Old 08-29-2011, 03:02 PM
  #35
Can you post a picture of the hub? Depending on the hub style of your truck, Mile Marker may also have something.
Old 09-01-2011, 05:35 PM
  #36
PireWagon's Avatar
how do you post pics to this form?? i did find the original window sticker and the owners manual.... the rear is the dana 70 limited slip with 4.88...yikes definitly have to find a diff rear axel to afford fuel...i will try to post a pic of the hub if you can explain how ... i dont see the attach button????
Old 09-02-2011, 02:19 AM
  #37
Hopefully this thread here helps. It's post numbers 3 and 4 that you will want to read.
https://moparforums.com/forums/f62/p...pictures-2128/
As far as the D70 having 4.88 gear and a LS, I'm not really surprised. That is what most of them came with. That or 4.10 (in the diesels). I am surprised that it youahve a D70 in the rear though as they were used in the 1 ton truck of that era. If you can, grab some pics and post them up of the rear axle too. Is your front axle a D44 or D60?
Old 09-08-2011, 06:42 AM
  #38
PireWagon's Avatar
Ok there are some corrections.. it is a 360360 with 410limited gears it is limited slip.. I think it is the dana 44 front.. I saw 44-8f or 8-d.. put on lift last night and found leaking axle seal on rear. Will fix that tonight along with brakes then I should be driving it... 78 w200. 360 four speed with 410 gears and the fulltime 4x4.. any body with same. Or similar setup have any mileage numbers???? Im thinking 12 or 13????
Old 08-06-2012, 02:49 PM
  #39
jovaxian's Avatar
manual locking hub
good afternoon, nice to join this community, I am from Caracas, Venezuela and wants to help me with a problem as you buy a dodge w200 not long ago and all this time and is uncomfortable 4x4 driving so, you will know which manual locking hub since the transfer is not in 2wd, thank you and hope you help me
Old 08-07-2012, 02:37 AM
  #40
You need to swap out the t-case to a part-time t-case and then install a set of D44 manual locking hubs. They are pretty much the same throughout the years.
AnthonyGW0114
08-22-2012 12:55 AM
dodge_dudetx
03-18-2011 12:17 PM
mach3107
02-09-2011 01:12 PM
Dave E
09-04-2009 03:56 AM
CAT-TECH
01-17-2008 06:33 PM
Quick Reply: 1978 dodge power wagon fulltime parttime 4x4 swap
