1992 D150 fuel line quick connector
Old 04-12-2017, 12:40 PM
JamesI's Avatar
Noticed fuel leaking on the ground. Feeling around on top of the tank, it appears to be one of the rubber lines going to the fuel pump. It has hose clamps on both ends and was leaking where it went into the pump. I tightened the hose clamp and it's not leaking now; but a friend told me there should be a quick connector there. Is it unsafe without the quick connector. If so, can anyone tell me which Dorman part # I need. Thanks for your help.
Old 04-12-2017, 02:13 PM
You need to replace the intire line.
Old 04-14-2017, 01:05 PM
I would have to see a picture of it. But if you get the line, there is a repair splice kit you can get to repair the line IF it's not to brittle from age.
But Dorman or Motor mite has the splice, you might have to pick up the fitting at a wrecking yard, and as Iowan said, at that point you might just as well replace the whole line if you can.
Just my 2 cents..
Old 04-14-2017, 08:32 PM
On my 1998 Van I had to repair the fuel line.. The OEM connectors were like a wet noodle Impossible to remove The Helper line of repair parts worked fine
Old 04-17-2017, 02:20 PM
JamesI's Avatar
Thanks for the replies. Rain and other things have kept me from working on it. I think maybe I can get some calipers on it to measure. I'll post the Dorman part # when I find out which one I need in case someone else has to replace the quick connector some time.
JamesI
08-18-2015 08:30 AM
JamesI
07-14-2015 01:15 AM
JamesI
07-02-2015 03:05 AM
ramjam
07-21-2010 10:43 AM
cide
05-17-2008 02:10 AM
Quick Reply: 1992 D150 fuel line quick connector
