1998 Chrysler Cirrus 2.5L wont start
Old Apr 30, 2010 | 07:05 PM
  #31
scotts74birds's Avatar
Just put the damn thing in already! HaHa! If it didnt go, it WILL! They ALL DO eventually. You've already done more checking than ANY service tech would have!
Old May 18, 2010 | 06:57 PM
  #32
crmzendrgone's Avatar
Ok I put the sensor in and still nothing exact same thing crank no start.????
Wow it has been awhile. I am going to try to check the volts again tonight. so what else I am going to read through the book some tonight(if life lets me)
Old May 19, 2010 | 10:08 AM
  #33
Ok I have taken pics.
I check the volts again and got like .1 when again the book says suppose to be 8.0.
I then ohmned the wire and got OL
So I start looking at the wire uncovering it and all and find that it is spliced in with the cam sensor wire.
So is that factory or did someone else do that? What else would cause and OL the wires look fine?
Old May 19, 2010 | 10:18 AM
  #34
Old Jun 11, 2010 | 04:42 PM
  #35
Exclamation FOR ANY ONE ELSE WITH THIS ISSUE
Took the car to the chrysler guru I use to work with and with in 2 minutes found it was the computer(course if i had a full blown scanner not a code reader I could have too).
So two hours labor and $450 computer later she is running. and all the before issues gone. guess when we all start to loose our minds we act funny before we just quit.
Old May 18, 2013 | 12:35 PM
  #36
angulo's Avatar
hey man that problem is the same with me right now
i have no spark
i changed the distributor and wasnt it !
any help ?
Old May 18, 2013 | 12:41 PM
  #37
angulo's Avatar
Old May 18, 2013 | 08:33 PM
  #38
duster3's Avatar
Are you checking for 8v at the pcm harness? If you have 8V there and only .2 at the sensor it the wire might be grounding out somewhere on the way.
May want to check for peace of mind, just my two cents
Edit: I just read that you fixed the problem, hope all stays well
Old May 18, 2013 | 08:36 PM
  #39
duster3's Avatar
@angulo,
The CPS also controls spark, this is a good possibility for your problem
Chryslercirrus1995
Dec 26, 2013 06:01 PM
carmanroads
Jul 16, 2012 02:58 AM
davidegruber@comcast.net
Mar 18, 2011 06:39 PM
BIGCJ
Oct 1, 2010 05:29 PM
corbinb
Aug 19, 2010 04:02 PM
