1964 Plymouth Belvedere w/orig AM radio Mopar Model 220
Old Apr 1, 2016 | 10:00 AM
Dad-Par's Avatar
Hello! Have 1964Plymouth Belvedere w/orig AM radio Mopar Model 220, w/single center dashspeaker. Installed new antenna, Radio was working fine. Used someCRC contact cleaner (non-greasy) thru on-off switch and dial stalks only ,reduced ‘scratching’ sound somewhat. Worked fine for a week. Nownot working. If I turn on radio, light comes on, still small amount of scratch,but gets louder as I turn up volume. Like it’s not picking upsignal. Replaced antenna, have good continuity between center pole ofplug and antenna mast. Good continuity again ground/outer portion ofantenna plug and inner fender attachment of antenna to body (was able to reachw/probe) and good continuity of antenna ground directly to Neg terminal Battery(new body ground wire) . Both antennas same continuity. Haveslowly turned Antenna Trim screw w/radio on in both directions with Noresult. Can anyone offer suggestion as to what’s going on? Have reprintChryslers shop manual w/wiring diagram, I can do basic checks, but not familiarw/interpreting extensive wiring diagram. Unsure if there is fuse/resister orsimilar inside.
Old Apr 1, 2016 | 10:08 AM
Is that a Bendix AM radio?
If so.... More than likely one of the resistors got damaged.... Just what it sounds like to me.
Old Apr 1, 2016 | 10:40 AM
Dad-Par's Avatar
Thanks RacerHog.
Old Apr 1, 2016 | 12:57 PM
If that unit is the Solid State unit.... Check with these guys to see if they can fix it for you..... http://www.wardsclassiccarradiorepair.com/
Their also are a couple of sharp guys over on the: http://www.imperialclub.com/
Thay use to help with some of the old radio stuff...
Hope this helps Yall get it working..... Keep us posted...
Old Apr 1, 2016 | 01:08 PM
Dad-Par's Avatar
It's all transistor, so maybe solid state. Not the expert, but will checkout sight you listed. MUCH THANKS!! RacerHog/DYNO-BOB!!
GeorgeB62
Sep 3, 2013 02:30 PM
ozzy
Jun 10, 2012 08:01 AM
eddynugget
Aug 30, 2011 11:37 AM
71RR08
Jul 20, 2009 03:34 PM
drzaeis
Apr 15, 2009 10:04 AM
