1971 Dodge Charger
Guest
Posts: n/a
The body of the car is in relatively good shape. My dad has had it in the garage for at least thirteen years now, so there isn't a lot of rust. I'm mostly looking for interior parts. The seats need to be reupholstered, the dash is cracked and most likely needs to be replaced, the ceiling is coming down and has holes in it and needs to be redone. Cheap parts for a 440 would be nice also. Piston rings, Intake Manifolds, etc. I would assume the engine parts are easier to find than the actual car parts. I just need to be pointed in the right direction
legendary interiors google that that should put you in the right dir thats where yearone gets there stuff from interior wise ,...... from what i been told but either place should have interior parts for your car
Guest
Posts: n/a
Originally Posted by Commando
I have stock 440 engine parts if you are interested, complete intake, exhaust manifolds, water pump and cam with timing chain and lifters. Let me know if you need any of that.
Originally Posted by pascualindio
I have a charger 1972 and I'm having the same problem
Need to know if you going original or not
I've some web addreses I can send you
I also need the roof to be redone. It's starting to wear out.
Guest
Posts: n/a
Mopar71,
Give us a holler or check out our website, we will be happy to assist you with your interior needs. Thanks. Eric @legendary Auto Interiors
(800)363-8804
www.legendaryautointeriors.com
(800)363-8804
Guest
Posts: n/a
Thanks, for the site. Looks like they do a pretty nice job fairly cheap.
That would be great. I'll have to look over everything and get a parts listing. I'll get back to you when I do.
Send away. The only thing I've really wanted to change were the brakes. Right now it's four wheel drum brakes and I've wanted to switch it up too disk. Though I'm unsure as to how much that would cost.
