1972 Charger engine swap
Old Jan 12, 2009 | 01:05 PM
  #31
looking very clean
Old Jan 14, 2009 | 12:53 AM
  #32
Apollo's Avatar
Burned a little midnight oil with this peculiar warm spell we're having here in California. Very warm night. Got most of the paint done. Just need to get the oil pan and a few other pieces. Water pump and other accessories should be here thursday. Its like second christmas.
Old Jan 14, 2009 | 02:35 AM
  #33
Polaradude's Avatar
Looks awesome, nice work
Old Jan 14, 2009 | 01:22 PM
  #34
nice painting
boy, i wish i had a warm spell
with wind chill, its 5 degrees here
Old Jan 14, 2009 | 01:43 PM
  #35
Apollo's Avatar
5 degrees . . .crucial. I was in shorts and a shirt in the garage until 1am or so.
Old Jan 14, 2009 | 05:14 PM
  #36
Lucky
haha
Old Jan 15, 2009 | 12:01 PM
  #37
Apollo's Avatar
Jegs came today. I looooooovvvveee getting parts in the mail. Good times. Just waiting on one more item. Should ship out next week due to it being back ordered. Its worth it though, its the icing on the cake. Got a Mildon windage tray and srcaper, aluminum water pump, aluminum housing, water neck and thermostat, flexalite fan, Dynomax 3" glasspacks . . .did i forget anything? Probably.
On a side note- The car gods must want me to finish this quick because its borderline hot today. Almost uncomfortable in pants and a shirt. Hooray for global climate change!!!
Old Jan 15, 2009 | 01:24 PM
  #38
cant wait to see it all finished
i wish it was that warm here
Old Jan 15, 2009 | 08:52 PM
  #39
challenger's Avatar
with all this global warming going on it should be +10 not -10 as it is right now so yes im mad that its warm where you are and you are doing a nice job and arn't you glad you went with that motor now ---- keep up the great work..
Old Jan 20, 2009 | 05:50 PM
  #40
Apollo's Avatar
Got a little more done on the project. . .
Old Jan 21, 2009 | 12:46 PM
  #41
Apollo's Avatar
Icing on the cake. . . .
Old Jan 21, 2009 | 01:28 PM
  #42
Commando's Avatar
Is that a 440 source water pump housing? If you haven't noticed yet there is a really big hole on the top, which when I called them they say is for a thermo sensor, so it turns out there is no spot for the thermo switch.
That looks sweet!
Old Jan 21, 2009 | 01:38 PM
  #43
lol
the icing makes it look amazing
Old Jan 21, 2009 | 01:59 PM
  #44
Apollo's Avatar
Thanks guys! I cant wait to drop the motor in.
No, its not a 440 source housing, although i was tempted to go with their housing because they are the only vendor that carries an original style housing with the lower outlet on the passenger side. Ended up just getting a standard aluminum one from Jegs.
The 3 threaded holes on top are all used. 2 are heater hose inlet/outlets and the 3rd that is being used in the pic is a temp sending i believe
Old Jan 21, 2009 | 02:04 PM
  #45
Polaradude's Avatar
Thats a fine cake bro. Well done.
Old Jan 21, 2009 | 02:06 PM
  #46
did you change cam or do any head work Apollo?
Old Jan 21, 2009 | 04:55 PM
  #47
Commando's Avatar
Oh ok, I got the one from 440 and where you have the vacuum switch I have my heater hose and the empty one next to it is too big to hold a switch, I had to put a plug there.
Old Jan 27, 2009 | 12:39 AM
  #48
Apollo's Avatar
No head work or cam yet . .
Test fit the motor tonight and ran in to the first issue. The damn headers. Anyone ever have fitment issues with headers in a charger? The header tube from cylinder #1 is making contact on the power steering unit as well as #3. Is there a better way to install the headers? Ive been trying with the motor slightly elevated, headers bolted down tight and the tranny completely free.
Aside from all that, I was able to pick up my new mopar daily driver . . .couldnt really pass up this up for 500 bucks. Just has a leaky heater core that leaves a nice puddle on the driverside floor. Totally fixable.
Old Jan 27, 2009 | 05:55 AM
  #49
Commando's Avatar
So are you trying to put it all together in one shot?
I know the header on the driver's side is fun as the steering shaft comes out and the header slides up from under the car, with the starter out. The passenger side just slides right up from the bottom as well.
Old Jan 27, 2009 | 11:13 AM
  #50
Apollo's Avatar
Ahhhhh . . .from under the car. I'll try that today. Thank you! I wasnt trying to put it in all together, but once the motor was in and sitting on the mounts, i lifted it back up a little and attempted to put them in from the top.
Old Jan 30, 2009 | 02:40 AM
  #51
Apollo's Avatar
SHES ALIVE!!!! After a whole bunch of swearing, beer, bloodied knuckles and quite a few trips to the local performance supplier the Charger runs!!! I ended up having to go with a set of hedman's. The first cylinders on both heads have the tube run up and over whereas the original set i had did not. Hence the clearance issues. Oh well.
Durring my trips to Vic Hubbords, our local performance spot,picked up an MSD Streetfire digital ignition, some Lokar carb hardware and some heat sheilding for the spark plug wires. The car will head to out to have the exhaust system welded tomorrow and the driveshaft heads out to be shortened. Fun stuff. More pics to come later and maybe some video if i can find a program to view or edit AVSHD or MTS files
Old Jan 30, 2009 | 03:03 AM
  #52
Polaradude's Avatar
Congrats man, post a pic of the burnout..after she's broke in.
Old Jan 30, 2009 | 04:17 AM
  #53
Commando's Avatar
I should have taken a look at the headers, as the new ones you got is the design I was thinking of, what are the apps for the old headers? They definitely look like they would cause issues.
Old Jan 30, 2009 | 08:59 AM
  #54
hedman headers seem to be the best for the 440's
what kind of paint did you use to paint the headers?
awsome job
Old Jan 30, 2009 | 09:42 AM
  #55
Apollo's Avatar
Well they looked like they would fit as there were bends in all the right places, just not enough of a bend i guess. I picked them up off craigslist listed as a set of generic 440 headers. Not b body specific. Lesson learned.
The paint you see on the hedmens is from an old can of high temp header paint i had lying around. It looks almost like a hammered finish and i messed it up a little bit in my frustration with the header issue all together. You can see the some of the scuff marks next to the "hedman" plate.
As soon as i get the drive shaft along with the new wheels and tires there will definitely be a succession of burn out and spirited driving videos
Old Jan 30, 2009 | 11:24 AM
  #56
haha
awsome
Old Feb 11, 2009 | 04:17 PM
  #57
Apollo's Avatar
Tires and wheels should be here this week. I cant find a program to display or edit the HD files from my camcorder so i had to use the phone for some vids. Sorry!!
First run-
http://www.youtube.com/watch?v=BYCi9S0MQag
Old Feb 11, 2009 | 06:03 PM
  #58
johnthegoalie's Avatar
thinkin with me dipstick
you need this to justify that scoop
Old Feb 11, 2009 | 06:14 PM
  #59
awsome video
Old Feb 11, 2009 | 10:02 PM
  #60
challenger's Avatar
awsome work Apollo congrats on the start up
