1972 satellite will not start
Old Dec 28, 2008 | 01:57 AM
mopar nate's Avatar
i had to replace the shift cable i would just by pass the neutral switch with a jump start wire and now that i have replaced the shift cable the car will not regularly start like the neutral switch is still engaged or something please help..
Old Dec 28, 2008 | 02:09 AM
BuckNeccid's Avatar
Did you check to make sure that your shifter arm is in the correct place when you adjusted/installed the shift cable? There's a pawl inside the tranny that closes the switch to allow the current to complete a ground when it's in the proper place. If it's not adjusted corectly, it may start in another gear. Good way to see if this is the problem... set your emergency brake and be very careful, then turn your key to the start position, and slowly pull your shifter through the gears. If your car starts anywhere except park or neutral, your cable is out of adjustment. If it still doesn't start, look for a disconnected wire on the tranny. It could have been knocked loose while you were installing the cable.
jbda
Apr 1, 2013 10:22 AM
superbeerob
Jul 22, 2010 01:57 PM
Scotteey
Jul 17, 2009 08:47 PM
gforcejunkie
Dec 13, 2008 05:26 AM
JimmyV
Aug 4, 2008 12:05 PM
