1980 Power wagon will not start
Old Jul 13, 2009 | 01:55 AM
Is that a new pump? If it is the old one, or even a new one, the inturnals could be out of wack. I'd try another one.
Have you pulled the dizzy out and looked at the gear yet? did you install the hold down bolt?
Old Jul 13, 2009 | 08:26 AM
Morrigan_Aria's Avatar
Hell kitten
Hope your fuel system from the pump back isn't shot. Mine was; it was the whole problem!
Old Jul 13, 2009 | 10:33 AM
scotts74birds's Avatar
Does it try to fire with ether?
Old Jul 13, 2009 | 09:07 PM
theomahamoparguy's Avatar
pour some gas directly into the carb opening [2 or 3 ounces]. Stand back and try startin her. Be careful, have fire extinguisher handy and old towel in cas it flames up [to smother it]. It should do something if the timing is anywhere near correct. If it does nothing, ya might have ignition issues, if it trys to start than you got fuel pump problems. By the way are you 100% sure you got the fuel lines right. Just checkin'.
Old Jul 13, 2009 | 09:16 PM
X2, especially if equipped with a feed and a return line to the tank.
Old Jul 15, 2009 | 09:53 AM
Edelbrock carbs like low PSI so you should be finr with 3-7 PSI. I run my j10 at 4.5-5 PSI and that has a Edelbrock 650 carb on it.
Old Jul 15, 2009 | 02:27 PM
challenger's Avatar
as far as not starting i would check all your upgrades to make sure you have installed them correctly -- sounds like its out just a touch with the timing or you might have the dist: out 180* take your time and go through every point possible as you dont want it firing wrong and burning up so take your time
Old Jul 17, 2009 | 02:51 AM
Way to go! glad to have been able to help.
Old Jul 17, 2009 | 02:55 AM
Polaradude's Avatar
Right on.
Old Jul 17, 2009 | 08:47 PM
nice job
H-pipes are good for dual exhaust
mcarroll
Aug 25, 2015 02:38 PM
jbda
Apr 1, 2013 10:22 AM
cnskate
Jul 20, 2009 07:11 PM
richinny
Jul 1, 2008 03:48 PM
summerj
Feb 6, 2008 08:34 PM
