1975 d200 carburetor replacement
Old Nov 9, 2009 | 03:38 AM
You can get a 2 barrel carb new and run that or get a 500CFM Edlebrock carb and the adapter plate to bolt a 4 barrel to a 2 barrel intake. If you are going to be doing any other performance upgrades to the motor, I'd get an Edlebrock Performer intake and bolt it all on at once and set it. You will need to get the kickdown linkage hooked up though to the new carb (there is plenty of info on here about that).
Old Nov 9, 2009 | 03:53 PM
theomahamoparguy's Avatar
Summit racing has a good deal on an intake manifold by Weiand called the Action plus. I believe it is $187. It has the "spreadbore" carb pattern. You could use a Thermo Quad or an AVS or even a Quadra Jet. Or just put an adaptor and run a holley type or AFB type.
Old Nov 10, 2009 | 03:34 AM
I got on of those and it did not line up with my 318 mounting holes (maybe it was just the intake that I got though). There are a lot of deals out there though that can be had. Heck, you might even be able to find a 4 barrel intake and carb on craigslist.
unruler
Oct 5, 2009 07:35 AM
Mar 24, 2009 02:14 AM
unruler
Feb 15, 2009 06:14 AM
Feb 12, 2009 09:33 AM
Apr 29, 2008 12:22 AM
