383 hesitation please help
Old Sep 23, 2008 | 07:45 AM
Commando's Avatar
Welcome to the forums.
Have you done anything to the transmission, or the drive train?
Old Sep 23, 2008 | 12:30 PM
BuckNeccid's Avatar
Do you have a stall convertor? From what I'm seeing with the way your engine's built, you won't start making power until 2000+ rpm. Next thing, if that Holley is a 770 cfm, it looks too large for off the line at a low rpm. If you have it stalling to at least 2400 rpm, and it still does that, first try the accelerator pump, make sure it works. If that's all good, my next suggestion would be to try a smaller cfm carb, with vacuum secondaries.
Old Sep 24, 2008 | 01:46 AM
BuckNeccid's Avatar
If it was mine, first thing I'd do would be to get a stall convertor, figure about 2400-2800 rpm. It will only stall to the point your engine makes torque to overcome it. That will let your engine "flash" to that point, probably the 2400 rpm point, before it engages. That would put you more in your power band, and let you use the power you're making, where you're making it. Driving it normally, you wont notice much difference, but when you nail it, that's when the convertor will flash. You will notice a slight decrease in gas mileage, if that worries you.
As far as the ignition kits, I've used a few, and never had any problems, but there's always that chance.
Jeff1515
Jul 15, 2014 03:03 PM
chlngr1970
Dec 9, 2013 05:49 PM
garthed
Sep 5, 2013 05:58 PM
bb48933
Aug 19, 2012 06:20 PM
DUST360
Oct 11, 2009 09:54 AM
