440 coronet project
Old 03-27-2012, 05:21 PM
daraj315's Avatar
440 coronet project
The project has begun. Got the motor out of a 73 rv 85,000 miles. Motor's tight. I'm just going to clean it up and slap some paint on it and put it in. I got the torque converter just in case. Any tips or pointers would be greatly appreciated!
Old 03-27-2012, 06:19 PM
Pictures please.
Old 03-27-2012, 07:53 PM
daraj315's Avatar
Here's pictures
Attached Thumbnails 440 coronet project-resampled952012-03-279518-31-0595132.jpg   440 coronet project-resampled952012-03-279517-17-0495160.jpg
Old 03-27-2012, 08:29 PM
That is a RV motor home 440 alright. You will need a center hump pan and some new motor mounts. You can go with the Schmacher Creative motor mounts.
Old 03-27-2012, 08:44 PM
daraj315's Avatar
So is it bad that it's an rv motor?
Old 03-27-2012, 11:31 PM
RV motor is fine, just remember it is a low compression motor, motor mounts are different, oil pan is different I would replace all the gaskets and maybe the timing chain, frost plugs, water pump. Maybe a valve job ??? depends on what it looks like inside with the valve cover off ??
At least replace the valve stem seals !!!
Old 03-28-2012, 06:03 AM
daraj315's Avatar
Everything looks really clean and tight. Except the cylinder heads. The exhaust ports are pretty gunked up. How much is it usually to have work on heads? Like port, valve job etc...
Old 04-11-2012, 11:59 AM
Dieselholic92's Avatar
If the exhaust ports are pretty gunked up, then that's usually a sign that there could be issues elsewhere in the motor. I would do a compression test on it just to make sure it doesn't have compression issues making it burn oil/not burn everything completely, hence the gunk in the ports. You just never know.
Old 04-11-2012, 12:57 PM
67hemidart's Avatar
rebuild it
it's $1000.00 to $1500 for a rebuild of you motor as long as the heads don't need too much work . well worth the time and effort of the install and removel and reinstall .
SteveRT
10-15-2014 04:24 PM
EvrMOPower
02-21-2014 07:24 AM
manny951
12-18-2012 10:49 PM
mystarcollectorcar.com
02-21-2011 08:29 PM
499coronet
02-18-2007 12:48 PM
Quick Reply: 440 coronet project
