440 coronet project
Old Mar 27, 2012 | 05:21 PM
daraj315's Avatar
440 coronet project
The project has begun. Got the motor out of a 73 rv 85,000 miles. Motor's tight. I'm just going to clean it up and slap some paint on it and put it in. I got the torque converter just in case. Any tips or pointers would be greatly appreciated!
Old Mar 27, 2012 | 06:19 PM
Pictures please.
Old Mar 27, 2012 | 07:53 PM
daraj315's Avatar
Here's pictures
Attached Thumbnails 440 coronet project-resampled952012-03-279518-31-0595132.jpg   440 coronet project-resampled952012-03-279517-17-0495160.jpg
Old Mar 27, 2012 | 08:29 PM
That is a RV motor home 440 alright. You will need a center hump pan and some new motor mounts. You can go with the Schmacher Creative motor mounts.
Old Mar 27, 2012 | 08:44 PM
daraj315's Avatar
So is it bad that it's an rv motor?
Old Mar 27, 2012 | 11:31 PM
RV motor is fine, just remember it is a low compression motor, motor mounts are different, oil pan is different I would replace all the gaskets and maybe the timing chain, frost plugs, water pump. Maybe a valve job ??? depends on what it looks like inside with the valve cover off ??
At least replace the valve stem seals !!!
Old Mar 28, 2012 | 06:03 AM
daraj315's Avatar
Everything looks really clean and tight. Except the cylinder heads. The exhaust ports are pretty gunked up. How much is it usually to have work on heads? Like port, valve job etc...
Old Apr 11, 2012 | 11:59 AM
Dieselholic92's Avatar
If the exhaust ports are pretty gunked up, then that's usually a sign that there could be issues elsewhere in the motor. I would do a compression test on it just to make sure it doesn't have compression issues making it burn oil/not burn everything completely, hence the gunk in the ports. You just never know.
Old Apr 11, 2012 | 12:57 PM
67hemidart's Avatar
rebuild it
it's $1000.00 to $1500 for a rebuild of you motor as long as the heads don't need too much work . well worth the time and effort of the install and removel and reinstall .
SteveRT
Oct 15, 2014 04:24 PM
EvrMOPower
Feb 21, 2014 07:24 AM
manny951
Dec 18, 2012 10:49 PM
mystarcollectorcar.com
Feb 21, 2011 08:29 PM
499coronet
Feb 18, 2007 12:48 PM
