'67 Coronet 500 Engine Wiring Issue
Old Jun 26, 2011 | 06:35 PM
ThumperNZ's Avatar
We have this '67 Coronet 500 Engine Wiring Issue related to the ballast wiring. The Engine has been changed from the 383ci to a 440ci and it has a MSD HEI ready to run Billet Distributor and requires a MSD Blaster 2 coil.
The problem seems to be that to run a 12v Ignition feed to the coil and the Distributor and this runs at 6.5v when the engine tries to run.
The car has also been fitted with a higher amperage altenator and an electronic voltage regulator, which seems to be hooked up to the ballast resistor.
How can we bypass all of this ballast wiring and get a simple 12v feed to the coil & distributor also while cranking?
19newport72
Mar 27, 2024 06:44 PM
GotScout
Jul 31, 2013 04:44 AM
kylegsh
Sep 24, 2010 06:55 PM
johnberetta
Feb 24, 2009 09:15 PM
GLASSMAN
Jan 8, 2008 01:34 PM
