68 Satellite map light wiring and Radio
Old May 13, 2009 | 02:05 PM
68satellite's Avatar
Junior Member
Question 68 Satellite map light wiring and Radio
I have a 68 Satellite that did not have a map light in it. I would like to install one. I pulled off the blank plate and could not see any existing wiring to connect it to. Should it be there or do I need to run wire. Also the light in the radio is not working. Where should I start with that? Thanks Ken.
Old May 13, 2009 | 02:30 PM
scotts74birds's Avatar
The dome light , if equipped should be a pink wire and a yellow wire. These are on the same run as the left and right pocket panel lights and the trunk light. Might be an unused connector under the dash with these wires.http://www.mymopar.com/downloads/196...oadRunnerA.JPG I think the radio light is internal and is just a bulb.
trevorrichland
Nov 17, 2013 09:17 PM
rgdodson54
Dec 22, 2012 08:09 PM
allcore1@hotmail.com
Nov 27, 2012 12:22 PM
mr.300
Feb 12, 2012 11:33 AM
Daytona45
Aug 22, 2009 10:33 PM
