68 Satellite, Modern Engine Swap
Old May 18, 2009 | 01:53 PM
You have an LA motor. All the Magnum motors that in the Ram trucks would not bolt up to the tranny that you have. The best that you can do is find an ealry 90s ram truck that has a TBI small block in it. grab the engine, wiring and everything else. Only other way to get EFI is to get a kit which can be big money depending on which way you go.
Old May 18, 2009 | 06:50 PM
68satellite's Avatar
Junior Member
Hi there, I really can,t help you much with your question, but I have a 68 Satellite with a two barrel and 66000 original miles. Does yours have a four barrel. I,am looking for an intake and 4 barrel or any other original parts for this engine. If your going to replace your engine and not rebuild I would be in the market for any parts if you are selling. Thanks Ken
Old May 19, 2009 | 09:37 AM
If you want OD, then i would suggest finding a 2wd ram 1500 and pulling out the motor, tranny, slip yoke, wiring and computers. People have done it and have talked about it on here, although I don't believe we have gotten any feed back from them about how it went.
If you go that way then you may be able to use the same motor mounts (or you'll have to make up new ones), you'll need to fab a new tranny crossmember and get a radiator for it all.
Old May 19, 2009 | 09:38 AM
Plus you'll have to do something about the exhaust, maybe even have a custom set of headers made up.
Seanzie1405
Jul 31, 2013 01:34 PM
Beepbeep71
Jul 24, 2012 06:02 PM
DartcustomcrusieR
Sep 4, 2011 12:44 PM
I love mopar
Apr 21, 2010 05:00 PM
GTlegs
Jan 8, 2010 09:03 PM
