69 Sat and 383
Old Jun 28, 2009 | 08:08 AM
Welcome to THE GREATEST FORUM EVER! (ha ha)
It looks like someone may have been trying to make a RR clone at one time. The headers should not be touching the trans pan or the steering lik that and the radiator is too low it looks like.
It looks to me like you will need to install some motor mount shims to help raise the motor some so that it will clear the steering. The passenger side header will have to be replaced or something. There is no reason for it to be like that.
It is a nice looking car that you have. Someone already did a lot of the work for you and now you just have to fix thier mistakes/lack to detail.
Old Jun 28, 2009 | 09:32 AM
Yes, you should pull the condensor out from infront of the radiator as this will allow more air flow through the radiator. Hold onto it if you ever plan on installing AC.
Look for a shroud on e-bay and craigslist. The shroud will help to direct the air through the radiator while idle. Without it, the fan will pull air through the radiator, but a lot of it will be pulled around it as well.
Sounds like you'll have to get that header fixed to help with the tranny issue. I'd install an alum tranny pan as that will help to keep the tranny fluid cooler.
Old Jun 28, 2009 | 04:16 PM
i think your hood is for a roadrunner
Old Jun 28, 2009 | 07:01 PM
Muswagon's Avatar
Looks like a Sport Sat hood, and Grill
Old Jul 15, 2009 | 06:47 AM
68satellite's Avatar
Junior Member
My 68 Satellite has the same hood.
BuckNeccid
Jun 6, 2011 09:15 PM
BuckNeccid
May 29, 2010 07:39 AM
bcuda67
Sep 30, 2009 06:44 PM
69SatSport
May 2, 2009 07:36 AM
68 Sat
Mar 16, 2009 08:13 AM
