72 Charger Drive Shaft HELP
Old Jul 8, 2011 | 01:37 PM
jeff1010's Avatar
I recently picked up a 1972 Charger, It did not come with a drive Shaft.
I have found on other posts that the one I need is 50 5/8 long, 3 1/4 diameter with 7290 u joints (Big Block). I have found one listed for sale that is advertised as 51" , Close Enough????? Also it has a flange ring at the rear of the shaft just in front of the U Joint attachments.
I have attached a picture If it loads correctly.
Is this the shaft I need?
Old Jul 8, 2011 | 10:19 PM
Sounds like it would work. Personally I would have one made up for your car
fresh , balanced ready to install !!! That flange would go to the front of the vehicle
Old Jul 9, 2011 | 02:17 AM
jeff1010's Avatar
I saw a longer one with the yoke installed after I posted, The flange is at the front. Thanks
Old Jul 9, 2011 | 01:43 PM
Then Get the longer one and have it shortened & re balanced...
Old Jul 18, 2011 | 12:00 PM
bboogieart's Avatar
Just wondering...
Why not use the one pictured rather than having one made, or re-made? Or find another one specifically for his car. What's the need for a new one? Is it just the harmonic balancer? I don't see a problem with it. The near 1/2" difference in length should pose no problem, should it?
Old Jul 18, 2011 | 11:03 PM
A trial fit would be in order.. You have no idea about the condition Is it twisted & about to fail, lost its balance weights, is it bent ? A new drive shaft would not have the big weight.
1975Powerwagon
Mar 22, 2015 09:25 AM
jeff1010
Aug 8, 2011 05:42 PM
mrstangblb
Apr 15, 2011 04:30 AM
timmie124
Dec 10, 2010 12:55 PM
71RR08
Aug 14, 2008 07:36 PM
